    Material mapping over surfaces
    renderpluginsextensions
    3 Posts 2 Posters 340 Views 2 Watching
      stewartn
      hi there
      newbie question....
      attached jpg shows imported geometry via microstaion / dwg import
      is it possible to align the paving material in the same direction on all faces?
      it does not want to attach if I make it a group or component
      I have 100's of faces like this so doing it one at a time using texture position rotate is not an option
      thanks in advance for any help - sorry if the question is a bit dumb!!
      • andybotA Offline
        andybot
        I would suggest using Fredo's Thrupaint plugin to map your surface, it's the perfect solution for this sort of problem.
          stewartn
          That's excellent, thanks for the recommendation!
