    Floating dialog boxes
    5 Posts 4 Posters 1.7k Views 4 Watching
    • P
      pomelo3d
      A small error when I minimize the window sketchup. If I have hidden floating dialog boxes when I maximize the window sketchup, floating dialog boxes are visible.
      • TIGT
        and... ?
        If this is a bug report then send it to SketchUp.com ?
        Or are you asking for advice ??
        • P
          pomelo3d
          ok, thanks, I will send a report.
          just asked about if someone had already reported.
          • T
            TR010101
            You should try and turn on the gravity tool. I believe it'll make the floating boxes come crashing back down to the ground. However, make sure you do not have anything built underneath, as it may break due to the boxes.
            Hope this helped.
            • GMthompsonG
              GMthompson
              When this happens to me I close the window if I have open windows where the tool bars are intact I save those and reopen su and the go back to normal.
              you can learn something everyday by paying attention
