    [Request] A plugin that makes sketchup remember...
    25 Posts 9 Posters 1.9k Views 9 Watching
    • masterpaulM Offline
      masterpaul
      Sketchup has an the option of typing fancy commands into the measurement box: such as "/" or "X" etc. This can be done in most built in commands.
      However lets say you have to an operation continually. Make sketchup Ctrl/move and then Divide ("/7"). This simple array stuff becomes tedious. Much like any other command that requires you to continuously type in commands in the measurement box. In an ideal scenario I would toogle a option and do the command once, and then sketchup would remember to "/7" instead of making me type it for the hundredth time.
      I just really wish sketch up would remember what I typed in the measurement box and do it automatically.
        Will be cool with the recall last function by Matt666 โ˜€
          Will be cool with the Recall Last Tool by Matt666 โ˜€
            masterpaul
            Recall last tool doesnt remember the last entered dimension. I'm not saving hardly any time, its a good plugin but its not really made for this.
            • BoxB Offline
              SU does remember things, a double click with push/pull will move the same distance again, for example.
              An image of what you want to do might help us give you some better workflow options.
                masterpaul
                Its not about moving the same distance, the distance always changes so you have to do it manually, however the command in the mesasurement box applied after doing "Ctrl move" always stays the same. Meaning I just want sketchup do remember to "/7" after the copy.
                http://i.imgur.com/t2NMNb7.jpg
                Different distances, same command in measurement box "/7". Imagine you have to this hundred of times.
                This potential plugin would not only work on copy/paste senario but on all senarios where the user would have to continuallsly input the same command into the measurement box.
                  Yes it's a pity that the measurement box don't accept a simple Ctrl + C, Ctrl + V!
                  Maybe a Plugin will an make that!
                    masterpaul
                    Ahh.. someday ๐Ÿ˜›
                    • gillesG Offline
                      gilles
                      ๐Ÿ˜ฒ
                      works on Mac, cmd+c cmd+v
                      • pbacotP Offline
                        type cntrl v or /7, what's the advantage?
                          @ Gilles
                          Damned! Works not on a PC!!! ๐Ÿ˜ฎ ๐Ÿ˜ฎ ๐Ÿ˜ฎ
                          Works on the Infos Entity but not on the VBC!!! ๐Ÿ˜ฎ ๐Ÿ˜ฎ ๐Ÿ˜ฎ
                          Or I miss something! ๐Ÿ˜ฒ
                          In this case if you have a numeric keyboard it's the same: 2 keys to press
                          but you must release the mouse if you are right handed! ๐Ÿ˜„
                          but.../77 will becomes more longer! ๐Ÿ’š
                          It is more speedy as soon as you have some long numbers or a complex formula,etc...! ๐Ÿ˜‰
                          • BoxB Offline
                            There are many ways to do what you want, a bit of planning and knowing your final result helps you decide what method is best.
                            Just one possible solution....
                            [screenr:2wrgo1eb]n2yH[/screenr:2wrgo1eb]
                              I use a keyboard with a standard numeric key set on the right. I learned to use that area quickly without looking at it. Typing /7 each time wouldn't take me any longer than activating a plugin.
                              Path/Copy would make sense for the specific application, though.
                              • BoxB Offline
                                I agree Dave, which is why I asked for an explanation of what he wanted to do. There are so many ways to do things a generic, I want to do this, doesn't really help.
                                  masterpaul
                                  I was more hopeing it would require using Ctrl+V or anything and it would do it automatically after you tick an option box or something.
                                  Generlly what I showed is a simple example, more complicated examples could involve me rescaling every single component or rotating it after I do an array. So this plugin would record your actions and repeat them automatically after you do CTRL Copy/paste.
                                    I think what you're after is Repeat Command.
                                    EG -
                                    Select an object, move it 18', then array it 5*
                                    Now if you use Repeat Command on the next selected abject it will perform the previous set of commands.
                                    Similar to a Photoshop Action.
                                      masterpaul
                                      [screenr:3a3p5u0m]n2yH[/screenr:3a3p5u0m]
                                      What happens when you don't always start nor end at the starting/ending points of the line?
                                        masterpaul
                                        EG -
                                        Yeah something like that.
                                        • jeff hammondJ Offline
                                          jeff hammond
                                          it's a choose your poison type of scenario..
                                          the move tool in sketchup is really sweet in the way it puts many operations on one tool without cluttering it up.. it's Move, Copy, Multiple linear array, divisible linear array, and a rotate tool all in one..
                                          on other apps, those will likely all be separate commands in which yes, they will more likely remember the last variable entered.. they'll likely be more powerful as well in individual command form but there is a tradeoff in overall program simplicity and the way sketchup's move tool works fits right in with the rest of the sketchup concept..
                                          with a single tool stacking multiple options, you can't necessarily expect it to remember the last entry.. because what happens if i want to use it to array an item then the next time i want to use , i want to simply move an item?
                                          that would be a problem..
                                          pretty much the solution, as i see it, would be to program a separate array tool which will remember it's last state.. but to me, if using sketchup, i'd rather just use the move tool and enter measurements on a per use basis.
                                          ymmv
                                          dotdotdot
                                            masterpaul
                                            ymmv
                                            Its either a separate array tool, or an tool which runs parrellel to all other tools which you can simply activate with a checkbox or something.
                                            How hard is it to learn ruby?
                                            • 1 / 2
