    Why to import a google earth image into sketchup?
    2 Posts 2 Posters 393 Views 2 Watching
    • F
      fadotian
      Why sometimes we need to import the image from google earth into sketchup? Is that used for its terrain? But I suppose if we want to draw a terrain analysis image, it seems the most convenient way is to draw the contour from a CAD file and produce a terrain in sketchup.
      So what the purpose to get image from google earch into sketchup?
      Thank you~
      • A
        Aerilius
        When you use "Add location", you import a map and terrain from Google Maps. At the same time, the coordinates are saved with your model.
        This is a convenient way to attach the coordinates to the model, but if you don't need the terrain you can delete it. If you have a more precise terrain you can use that. Users can write plugins to use other tools for geo-referencing.
