    Get MAC Address
    55 Posts 8 Posters 6.5k Views 8 Watching
    • G Offline
      Garry K
      This works in Windows 7
      def get_mac_address()
      	return @@mac_address if defined?( @@mac_address )
      	if ( ( RUBY_PLATFORM =~ /darwin/i ) == nil )
      		cmd = 'ipconfig /all'
      	else
      		cmd = 'ifconfig'
      	macs = []
      	lines = %x[#{cmd}].split("\n").grep( /^.*\s([0-9a-f|A-F]{2}[:-]){5}([0-9a-f|A-F]{2})$/ )
      	lines.each{|line| macs << line.strip[-17,17] }
      	@@mac_address = macs.first.gsub( '-', ':' )
      • G Offline
        Garry K
        Thanks pgarmyn - I was just confirming the language thing
        I did try running the code that you posted earlier - but it gave me an error so I decided this was a good opportunity to learn more.
        I have cleaned this up so if it is benefit to others
        ` def get_mac_address()
        mac_addr = []
        cmd = @@windows ? 'ipconfig /all' : 'ifconfig'
        # choose lines that have only six pairs of 2 char hex values separated by either a : or -
        # pattern must start with a space and be at the end of the line
        # there can be white space at the end of the line
        lines = %x[#{cmd}].split("\n").grep( /\s([0-9A-F]{2}[-:]){5}([0-9A-F]{2})\s*$/ )
        lines.each{|line| mac_addr << (line.strip[-17,17]).gsub( /-/, ':' ) }
        # if windows and we have more than 1 mac address use the second one otherwise use the first
        # if not windows then use the first address
        index = @@windows && mac_addr.length > 1 ? 1 : 0
        @@mac_address = mac_addr[index]
        end`
          driven
          @gary
          couple of changes needed to run on my mac,
          got rid of class variables
          added windows =
          added simplified regex = with .. for grep
          windows  = ( ( RUBY_PLATFORM =~ /darwin/i ) == nil )
          return mac_address if defined?( mac_address )
          mac_addr = []
          cmd = windows ? 'ipconfig /all' ; 'ifconfig'
          # choose lines that have only six pairs of 2 char hex values separated by either a ; or -
          regex = Regexp.compile("(..[;-]){5}..")
          lines = %x[#{cmd}].split("\n").grep( regex )
          lines.each{|line| mac_addr << (line.strip[-17,17]).gsub( /-/, ';' ) }
          index = windows && mac_addr.length > 1 ? 1 ; 0
          return mac_address
          > get_mac_address 00:1e:c4:16:08:46
          • G Offline
            Garry K
            Thank-you very much, I appreciate this, since I don't have access to a mac.
            I will test on Windows with your simplified regex.
            You show the mac_address as lower case - can you confirm that is indeed the output.
            Also - off topic - but how do you get the source code to go into the embedded window?
              driven
              yes it's lower-case, I realised that obscuring it in my other posts was counter productive, so I just adjusted only the number values to show the return this time...
              the one with the red circle...
              • G Offline
                Garry K
                Thanks again. I checked the code for windows and it works fine.
                I've added an upcase on the following line
                lines.each{|line| mac_addr << (line.strip[-17,17]).upcase().gsub( /-/, ':' ) }
                • jaimedaJ Offline
                  jaimeda
                  Hello
                  This works fine in Sketchup 2013 but not in 2014.
                  Any tips?
                  • tt_suT Offline
                    tt_su
                    Due to the upgrade of the Ruby core this broke. We haven't been able to figure out why. But the workaround is to pipe the result from the command to a temporary file and read it after executing the command.
                    <span class="syntaxdefault"><br />tempfile&nbsp;</span><span class="syntaxkeyword">=&nbsp;</span><span class="syntaxstring">"C;/Users/Thomas/Desktop/temp.txt"<br /></span><span class="syntaxkeyword">`</span><span class="syntaxstring">ipconfig&nbsp;/all&nbsp;>&nbsp;#{tempfile}</span><span class="syntaxkeyword">`<br /></span><span class="syntaxdefault">puts&nbsp;File</span><span class="syntaxkeyword">.</span><span class="syntaxdefault">read</span><span class="syntaxkeyword">(</span><span class="syntaxdefault">tempfile</span><span class="syntaxkeyword">)<br />&nbsp;</span><span class="syntaxdefault"></span>
                    • jaimedaJ Offline
                      jaimeda
                      Thanks Thomas.
                      It works perfectly.
                      • G Offline
                        Garry K
                        <span class="syntaxdefault"><br />tempfile </span><span class="syntaxkeyword">=</span><span class="syntaxdefault"> </span><span class="syntaxstring">"C;/Users/Thomas/Desktop/temp.txt"<br /></span><span class="syntaxkeyword">`</span><span class="syntaxstring">ipconfig /all > #{tempfile}</span><span class="syntaxkeyword">`<br /></span><span class="syntaxdefault">puts File</span><span class="syntaxkeyword">.</span><span class="syntaxdefault">read</span><span class="syntaxkeyword">(</span><span class="syntaxdefault">tempfile</span><span class="syntaxkeyword">)<br /></span><span class="syntaxdefault"> </span>
                        In my C++ programming for windows I would create a temp file this way
                        tempfp = tmpfile();
                        Is there anything in Sketchup that would do the same for both Windows and Mac?
                        • tt_suT Offline
                          tt_su
                          Well,... since we now have the Ruby Standard Library available: http://ruby-doc.org/stdlib-2.0.0/libdoc/tempfile/rdoc/Tempfile.html
                          So an updated example would be:
                          <span class="syntaxdefault"><br /></span><span class="syntaxkeyword">require&nbsp;</span><span class="syntaxstring">'tempfile'<br /></span><span class="syntaxdefault">file&nbsp;</span><span class="syntaxkeyword">=&nbsp;</span><span class="syntaxdefault">Tempfile</span><span class="syntaxkeyword">.new(</span><span class="syntaxstring">'my_prefix'</span><span class="syntaxkeyword">)<br /></span><span class="syntaxdefault">file</span><span class="syntaxkeyword">.</span><span class="syntaxdefault">close<br /></span><span class="syntaxkeyword">`</span><span class="syntaxstring">ipconfig&nbsp;/all&nbsp;>&nbsp;#{file.path}</span><span class="syntaxkeyword">`<br /></span><span class="syntaxdefault">puts&nbsp;File</span><span class="syntaxkeyword">.</span><span class="syntaxdefault">read</span><span class="syntaxkeyword">(</span><span class="syntaxdefault">file</span><span class="syntaxkeyword">.</span><span class="syntaxdefault">path</span><span class="syntaxkeyword">)<br /></span><span class="syntaxdefault">file</span><span class="syntaxkeyword">.</span><span class="syntaxdefault">unlink<br /></span>
                          • Dan RathbunD Offline
                            Dan Rathbun
                            Weirdly the backquotes, & %x strings which use the ()` method, work on my machine.
                            And I verified that I do not have the backquote_patch.rb (that I proposed,) loaded.
                            I'm not here much anymore.
                            • Chris FullmerC Offline
                              We have seen that if a user drags a skp model onto their SU icon, then they work. but if they double click on a skp model file, or double click on the SU icon, then it does not work. Are you seeing it work in both scenarios?
                              All my Plugins I've written
                              • G Offline
                                Garry K
                                <span class="syntaxdefault"><br />require </span><span class="syntaxstring">'tempfile'<br /></span><span class="syntaxdefault">file </span><span class="syntaxkeyword">=</span><span class="syntaxdefault"> Tempfile</span><span class="syntaxkeyword">.new(</span><span class="syntaxstring">'my_prefix'</span><span class="syntaxkeyword">)<br /></span><span class="syntaxdefault">file</span><span class="syntaxkeyword">.</span><span class="syntaxdefault">close<br /></span><span class="syntaxkeyword">`</span><span class="syntaxstring">ipconfig /all > #{file.path}</span><span class="syntaxkeyword">`<br /></span><span class="syntaxdefault">puts File</span><span class="syntaxkeyword">.</span><span class="syntaxdefault">read</span><span class="syntaxkeyword">(</span><span class="syntaxdefault">file</span><span class="syntaxkeyword">.</span><span class="syntaxdefault">path</span><span class="syntaxkeyword">)<br /></span><span class="syntaxdefault">file</span><span class="syntaxkeyword">.</span><span class="syntaxdefault">unlink<br /></span>
                                This is great for 2014 and forward - but what if you want to support earlier versions.
                                I guess we have to either use a one size fits all strategy or check the version an branch appropriately.
                                  Dan Rathbun
                                  There are whole topic threads on using the TEMP directory.
                                  No problem on Mac OSX...
                                  The issue on PC is unicode characters in usernames, which cause Ruby 1.8.x to choke.
                                  So some coders create a TEMP subdir of THEIR specific plugin's folder.
                                  (I think this is better than creating any temp folders in the root dir of the system drive.)
                                    Dan Rathbun
                                    @chris fullmer said:
                                    ... but if they double click on a skp model file, or double click on the SU icon, then it does not work. Are you seeing it work in both scenarios?
                                    NO neither.
                                    I see now, I either have used a pinned shortcut copy (of the desktop icon,) on the taskbar, or a copy on the StartMenu, or from a popup menu of the Desktop taskbar.
                                    These are all single-click ways of launching SketchUp. I usually start SU this way because the Desktop is covered up.
                                    • jaimedaJ Offline
                                      jaimeda
                                      I think this works in 2014 and earlier
                                      <span class="syntaxdefault">IO</span><span class="syntaxkeyword">.</span><span class="syntaxdefault">popen</span><span class="syntaxkeyword">(</span><span class="syntaxstring">"ipconfig/all >temp.txt"</span><span class="syntaxkeyword">)</span><span class="syntaxdefault"> </span><span class="syntaxkeyword">{|</span><span class="syntaxdefault">fd</span><span class="syntaxkeyword">|</span><span class="syntaxdefault"> fd</span><span class="syntaxkeyword">.</span><span class="syntaxdefault">readlines</span><span class="syntaxkeyword">}<br /></span><span class="syntaxdefault">lines </span><span class="syntaxkeyword">=</span><span class="syntaxdefault"> open</span><span class="syntaxkeyword">(</span><span class="syntaxstring">"temp.txt"</span><span class="syntaxkeyword">).</span><span class="syntaxdefault">readlines<br />puts</span><span class="syntaxkeyword">(</span><span class="syntaxdefault">lines</span><span class="syntaxkeyword">)<br /></span><span class="syntaxdefault"> </span>
                                      • G Offline
                                        Garry K
                                        Does this code work with Mac OS.
                                        With windows the tempfile goes to desktop and gets discarded when finished.
                                        Where does the file go for Mac OS and do we have rights?
                                              # do this for testing on a mac
                                              @@windows = false
                                              # do this for testing on windows
                                              # @@windows = false
                                              mac_addr = []
                                              cmd = @@windows ? 'ipconfig /all' ; 'ifconfig'
                                              # separated by either a ; or -
                                              regex = Regexp.compile('(..[;-]){5}..')
                                              tempfile = "temp.txt"
                                              `#{cmd} > #{tempfile}`
                                              File.open(tempfile, 'r') do |file|
                                                lines = file.grep(regex)
                                                lines.each { |line| mac_addr << (line.strip[-17, 17]).upcase().gsub(/-/, ';') }
                                              File.unlink(tempfile)
                                              # then use the second one otherwise use the first
                                              index = @@windows && mac_addr.length > 1 ? 1 ; 0
                                          Dan Rathbun
                                          The temp file only goes to the desktop by chance that your current working directory is pointing at the desktop directory.
                                          WIN = RUBY_PLATFORM !~ /darwin/i OSX =( not WIN ) desktop_dir = WIN ? "#{ENV['USERPROFILE']}/Desktop" : "~/Desktop"
                                          Assuming that the name of the directory is not language localized, but it likely IS.
                                          You should not ever assume some other script has not changed the working directory.
                                          All older SketchUp versions attempted to set it to the user's home directory.
                                          SketchUp 2014 (on my machine,) has left me in "#{ENV['SystemRoot']}/System32" (why I do not know, but have asked.)
                                          To see what the current working directory is, use:
                                          Dir::getwd
                                          or, it's alias:
                                          Dir::pwd
                                          To temporarily change the working directory (and have it change back to whatever it was,) use the blockform of the Dir::chdir class method.
                                          Dir;;chdir( RUBY_PLATFORM !~ /darwin/i ? "#{ENV['USERPROFILE']}/Desktop" ; "~/Desktop" ) {
                                                @@windows = false
                                                # @@windows = false
                                                mac_addr = []
                                          } # chdir block
                                          To test for access rights:
                                          File::directory?( dirname ) && File::writable?( dirname )
                                          See the File class for other class query methods to determine access info: executable?(), executable_real?(), readable?(), readable_real?(), writable_real?, etc.
                                          Be aware that path strings with unicode characters will not work well under Ruby 1.8.x on PC. (Mac OSX does not have these problems.)
                                          • G Offline
                                            Garry K
                                            Thanks Dan. I should have thought about the whole issue of current working directory. This has been true since the beginning of DOS.
                                            I'm going to put a config folder in my own plugin folder. I can put the temp.txt file there. I can also use the folder to put user custom settings so that updates don't overwrite user settings.
                                            • 2 / 3
