    Get MAC Address
    55 Posts 8 Posters 7.8k Views 8 Watching
      Garry K
      Thanks again. I checked the code for windows and it works fine.
      I've added an upcase on the following line
      lines.each{|line| mac_addr << (line.strip[-17,17]).upcase().gsub( /-/, ':' ) }
      • jaimedaJ Offline
        jaimeda
        Hello
        This works fine in Sketchup 2013 but not in 2014.
        Any tips?
        • tt_suT Offline
          tt_su
          Due to the upgrade of the Ruby core this broke. We haven't been able to figure out why. But the workaround is to pipe the result from the command to a temporary file and read it after executing the command.
          <span class="syntaxdefault"><br />tempfile&nbsp;</span><span class="syntaxkeyword">=&nbsp;</span><span class="syntaxstring">"C;/Users/Thomas/Desktop/temp.txt"<br /></span><span class="syntaxkeyword">`</span><span class="syntaxstring">ipconfig&nbsp;/all&nbsp;>&nbsp;#{tempfile}</span><span class="syntaxkeyword">`<br /></span><span class="syntaxdefault">puts&nbsp;File</span><span class="syntaxkeyword">.</span><span class="syntaxdefault">read</span><span class="syntaxkeyword">(</span><span class="syntaxdefault">tempfile</span><span class="syntaxkeyword">)<br />&nbsp;</span><span class="syntaxdefault"></span>
          • jaimedaJ Offline
            jaimeda
            Thanks Thomas.
            It works perfectly.
              Garry K
              <span class="syntaxdefault"><br />tempfile </span><span class="syntaxkeyword">=</span><span class="syntaxdefault"> </span><span class="syntaxstring">"C;/Users/Thomas/Desktop/temp.txt"<br /></span><span class="syntaxkeyword">`</span><span class="syntaxstring">ipconfig /all > #{tempfile}</span><span class="syntaxkeyword">`<br /></span><span class="syntaxdefault">puts File</span><span class="syntaxkeyword">.</span><span class="syntaxdefault">read</span><span class="syntaxkeyword">(</span><span class="syntaxdefault">tempfile</span><span class="syntaxkeyword">)<br /></span><span class="syntaxdefault"> </span>
              In my C++ programming for windows I would create a temp file this way
              tempfp = tmpfile();
              Is there anything in Sketchup that would do the same for both Windows and Mac?
              • tt_suT Offline
                tt_su
                Well,... since we now have the Ruby Standard Library available: http://ruby-doc.org/stdlib-2.0.0/libdoc/tempfile/rdoc/Tempfile.html
                So an updated example would be:
                <span class="syntaxdefault"><br /></span><span class="syntaxkeyword">require&nbsp;</span><span class="syntaxstring">'tempfile'<br /></span><span class="syntaxdefault">file&nbsp;</span><span class="syntaxkeyword">=&nbsp;</span><span class="syntaxdefault">Tempfile</span><span class="syntaxkeyword">.new(</span><span class="syntaxstring">'my_prefix'</span><span class="syntaxkeyword">)<br /></span><span class="syntaxdefault">file</span><span class="syntaxkeyword">.</span><span class="syntaxdefault">close<br /></span><span class="syntaxkeyword">`</span><span class="syntaxstring">ipconfig&nbsp;/all&nbsp;>&nbsp;#{file.path}</span><span class="syntaxkeyword">`<br /></span><span class="syntaxdefault">puts&nbsp;File</span><span class="syntaxkeyword">.</span><span class="syntaxdefault">read</span><span class="syntaxkeyword">(</span><span class="syntaxdefault">file</span><span class="syntaxkeyword">.</span><span class="syntaxdefault">path</span><span class="syntaxkeyword">)<br /></span><span class="syntaxdefault">file</span><span class="syntaxkeyword">.</span><span class="syntaxdefault">unlink<br /></span>
                • Dan RathbunD Offline
                  Dan Rathbun
                  Weirdly the backquotes, & %x strings which use the ()` method, work on my machine.
                  And I verified that I do not have the backquote_patch.rb (that I proposed,) loaded.
                  I'm not here much anymore.
                  • Chris FullmerC Offline
                    We have seen that if a user drags a skp model onto their SU icon, then they work. but if they double click on a skp model file, or double click on the SU icon, then it does not work. Are you seeing it work in both scenarios?
                      Garry K
                      <span class="syntaxdefault"><br />require </span><span class="syntaxstring">'tempfile'<br /></span><span class="syntaxdefault">file </span><span class="syntaxkeyword">=</span><span class="syntaxdefault"> Tempfile</span><span class="syntaxkeyword">.new(</span><span class="syntaxstring">'my_prefix'</span><span class="syntaxkeyword">)<br /></span><span class="syntaxdefault">file</span><span class="syntaxkeyword">.</span><span class="syntaxdefault">close<br /></span><span class="syntaxkeyword">`</span><span class="syntaxstring">ipconfig /all > #{file.path}</span><span class="syntaxkeyword">`<br /></span><span class="syntaxdefault">puts File</span><span class="syntaxkeyword">.</span><span class="syntaxdefault">read</span><span class="syntaxkeyword">(</span><span class="syntaxdefault">file</span><span class="syntaxkeyword">.</span><span class="syntaxdefault">path</span><span class="syntaxkeyword">)<br /></span><span class="syntaxdefault">file</span><span class="syntaxkeyword">.</span><span class="syntaxdefault">unlink<br /></span>
                      This is great for 2014 and forward - but what if you want to support earlier versions.
                      I guess we have to either use a one size fits all strategy or check the version an branch appropriately.
                        Dan Rathbun
                        There are whole topic threads on using the TEMP directory.
                        No problem on Mac OSX...
                        The issue on PC is unicode characters in usernames, which cause Ruby 1.8.x to choke.
                        So some coders create a TEMP subdir of THEIR specific plugin's folder.
                        (I think this is better than creating any temp folders in the root dir of the system drive.)
                          Dan Rathbun
                          @chris fullmer said:
                          ... but if they double click on a skp model file, or double click on the SU icon, then it does not work. Are you seeing it work in both scenarios?
                          NO neither.
                          I see now, I either have used a pinned shortcut copy (of the desktop icon,) on the taskbar, or a copy on the StartMenu, or from a popup menu of the Desktop taskbar.
                          These are all single-click ways of launching SketchUp. I usually start SU this way because the Desktop is covered up.
                          • jaimedaJ Offline
                            jaimeda
                            I think this works in 2014 and earlier
                            <span class="syntaxdefault">IO</span><span class="syntaxkeyword">.</span><span class="syntaxdefault">popen</span><span class="syntaxkeyword">(</span><span class="syntaxstring">"ipconfig/all >temp.txt"</span><span class="syntaxkeyword">)</span><span class="syntaxdefault"> </span><span class="syntaxkeyword">{|</span><span class="syntaxdefault">fd</span><span class="syntaxkeyword">|</span><span class="syntaxdefault"> fd</span><span class="syntaxkeyword">.</span><span class="syntaxdefault">readlines</span><span class="syntaxkeyword">}<br /></span><span class="syntaxdefault">lines </span><span class="syntaxkeyword">=</span><span class="syntaxdefault"> open</span><span class="syntaxkeyword">(</span><span class="syntaxstring">"temp.txt"</span><span class="syntaxkeyword">).</span><span class="syntaxdefault">readlines<br />puts</span><span class="syntaxkeyword">(</span><span class="syntaxdefault">lines</span><span class="syntaxkeyword">)<br /></span><span class="syntaxdefault"> </span>
                              Garry K
                              Does this code work with Mac OS.
                              With windows the tempfile goes to desktop and gets discarded when finished.
                              Where does the file go for Mac OS and do we have rights?
                                    # do this for testing on a mac
                                    @@windows = false
                                    # do this for testing on windows
                                    # @@windows = false
                                    mac_addr = []
                                    cmd = @@windows ? 'ipconfig /all' ; 'ifconfig'
                                    # choose lines that have only six pairs of 2 char hex values
                                    # separated by either a ; or -
                                    regex = Regexp.compile('(..[;-]){5}..')
                                    tempfile = "temp.txt"
                                    `#{cmd} > #{tempfile}`
                                    File.open(tempfile, 'r') do |file|
                                      lines = file.grep(regex)
                                      lines.each { |line| mac_addr << (line.strip[-17, 17]).upcase().gsub(/-/, ';') }
                                    File.unlink(tempfile)
                                    # if windows and we have more than 1 mac address
                                    # then use the second one otherwise use the first
                                    # if not windows then use the first address
                                    index = @@windows && mac_addr.length > 1 ? 1 ; 0
                                    @@mac_address = mac_addr[index]
                                Dan Rathbun
                                The temp file only goes to the desktop by chance that your current working directory is pointing at the desktop directory.
                                WIN = RUBY_PLATFORM !~ /darwin/i OSX =( not WIN ) desktop_dir = WIN ? "#{ENV['USERPROFILE']}/Desktop" : "~/Desktop"
                                Assuming that the name of the directory is not language localized, but it likely IS.
                                You should not ever assume some other script has not changed the working directory.
                                All older SketchUp versions attempted to set it to the user's home directory.
                                SketchUp 2014 (on my machine,) has left me in "#{ENV['SystemRoot']}/System32" (why I do not know, but have asked.)
                                To see what the current working directory is, use:
                                Dir::getwd
                                or, it's alias:
                                Dir::pwd
                                To temporarily change the working directory (and have it change back to whatever it was,) use the blockform of the Dir::chdir class method.
                                Dir;;chdir( RUBY_PLATFORM !~ /darwin/i ? "#{ENV['USERPROFILE']}/Desktop" ; "~/Desktop" ) {
                                      @@windows = false
                                      # @@windows = false
                                      mac_addr = []
                                } # chdir block
                                To test for access rights:
                                File::directory?( dirname ) && File::writable?( dirname )
                                See the File class for other class query methods to determine access info: executable?(), executable_real?(), readable?(), readable_real?(), writable_real?, etc.
                                Be aware that path strings with unicode characters will not work well under Ruby 1.8.x on PC. (Mac OSX does not have these problems.)
                                  Garry K
                                  Thanks Dan. I should have thought about the whole issue of current working directory. This has been true since the beginning of DOS.
                                  I'm going to put a config folder in my own plugin folder. I can put the temp.txt file there. I can also use the folder to put user custom settings so that updates don't overwrite user settings.
                                  • tt_suT Offline
                                    tt_su
                                    For SketchUp versions older than SU2014 that might cause problems if the user doesn't have full permissions to the Plugins folder since Windows locks down Program Files quite tight. Ruby will in many cases not have write access.
                                      Garry K
                                      OK - then what do you suggest. I will need to find a location to temporarily write a file. This will be for Windows and Mac.
                                      I suppose I could use one strategy for SU 2014 and another for older versions.
                                      • tt_suT Offline
                                        tt_su
                                        For temporary files in SketchUp < 2014 I would write to the temp folder based on that the ENV variable gives you:
                                        temp_path = File.expand_path(ENV['TMPDIR'] || ENV['TMP'] || ENV['TEMP'])
                                        For settings and persistent preferences, if you want to write that to file it will get tricky in older SketchUp. I stick with using Sketchup.write_default/read_default.
                                        This is one of those areas where you probably would end up with code branching for the different ruby interpreters.
                                          Dan Rathbun
                                          But... the TMP/TEMP directory is in the user path, and IF the username has unicode characters, then older versions on PC have problems.
                                          We would need to employ tricks like in TIG's PCFIleTools.
                                          http://sketchucation.com/forums/viewtopic.php?f=180%26amp;t=43007%26amp;p=385472
                                          • tt_suT Offline
                                            tt_su
                                            On the machines I tested this on the ENV variable would return DOS 8.3 short filepaths for the temp paths - and that works for Ruby 1.8 since they call the ASCII versions of the Windows file functions that can handle that.
                                            That said, there's always a change that ENV variables might be altered by someone, but it has worked fine for several years.
                                            In theory you could use Win32 API calls under Ruby 1.8 to get short 8.3 filepaths and pass that to the Ruby File methods.
                                            • 2 / 3
