How do I turn on the Input Window?
I just installed SUv8 and I don't have the input window down at the bottom. I have forgotten how to tell the program to show it. It's probably right in front of my face! Help anyone?
Try to maximize the SketchUp window, sometimes the bottom is hidden behind the taskbar...
Click on the little square button in the upper right corner to maximize the SketchUp window to the screen.
Cotty wins!
Are you sure you mean SU8 because in SU13 you can open and close it with a right click on the bottom bar.
Thanks, I had it all along! It was in the lower right corner, not the lower left, as in SU13. I was just looking in the wrong place. I have to use SU8 when creating models to import into my CAD software, which doesn't support SU13 yet.
You can save as SU8 in SU2013...
Would you please update your profile to include which version of SU and OS you are using? Thanks.
Thanks for that as well. I see now that you can "Save As" all the way back to V3!
Register LoginAdvertisement
