    Modeling this Ralph Pucci Chandelier
    27 Posts 7 Posters 2.0k Views 7 Watching
    • olisheaO
      olishea
      I made a sphere, offset the faces, deleted inner faces, used FFD to twist the globe and squash it. Then JPP and Artisan. 😳 Not quads though. 😞 And it only took 20 minutes to display the geometry. I can make a pretty photo-realistic looking tree with 5 times less polys!
      oli
      • olisheaO
        olishea
        @cotty said:
        I think there is one basic element in there which you "only" have to position correctly...
        ONLY!! lol Just tried, failed, gave up πŸ˜„
        What's worse is that these elements seem to overlap each other in places. ❓
        oli
        • olisheaO
          olishea
          Got something a little bit closer.
          Left side I just manually copied Cotty's component around a globe. Right side I used fur plugin. Managed to get some good overlaps but it's still very messy. πŸ˜†
          The fourth image just uses less components. You have to use a sphere with less faces as fur plugin sometimes uses more than one component per face, even though I told it not to. πŸ˜†
          Fifth image I squashed a sphere using FFD and then ran the fur plugin. I can't think of any other way to do it. Once you use the Cotty component it's a 2 minute job with fur plugin.
          oli
          • olisheaO
            olishea
            How is the real lamp illuminated? From the bottom dish?
            I'll stop posting now I don't want to spam the thread lol
            oli
            • massimoM
              massimo Moderator
              Well done Oli, you're getting close. πŸ‘
              One observation is that the elements seem to be bent following the curvature however. Now just use Fredo's bending tool on each of those...πŸ˜›
              • olisheaO
                olishea
                One observation is that the elements seem to be bent however... πŸ˜›
                Cheers massimo,
                I know...You can see at the equator of my model how it looks faceted. 😞
                Problem is, the squashed globe has different curvature at different points. The equator is the most bent, then almost flat as it rises. hmmmmmm. πŸ˜† If it was a sphere then things would be much easier.
                I think this is possible in SU but lots of manual work required as Rich said.
                Could even use 3 different components for the fur plugin. Slightly bent, bent and majorly bent!
                Or how about intersecting the components into the globe? Then JPP the result, that would work. β˜€
                The mind boggles! πŸ˜†
                oli
                • BoxB
                  Wouldn't the most straight forward way be to, shape the sphere then take one longitudinal segment as a starting point and draw the shapes you want, extrude them and subdivide/smooth. Make that a component and rotate array it.
                  • 2 / 2
