    Sample Model for Rendering - Ferrari
    79 Posts 25 Posters 28.3k Views 25 Watching
    • xonptX Offline
      xonpt
      wow, there are some reeeeeally perfect renders out here!
      here is my try... still learning my way through VRay... 😐
      VRay for Sketchup, 9 minutes on my prehistoric Core2Duo machine
      only color correction on PS
      • tademaT Offline
        tadema
        Hope I'm not too late.
        Xonpt that colour looks great.
        John
        • Al HartA Offline
          Al Hart
          John
          Nice overall scene - nice reflection on the car
          What renderer did you use? Any other comments to add to the image?
          Al Hart
          http://wiki.renderplus.com/images/e/ef/Render_plus_colored30x30).PNG
          IRender nXt from Render Plus
          • tademaT Offline
            tadema
            Sorry Al, I used V-ray
            John
            • xonptX Offline
              xonpt
              John
              sorry for the noob question, but im trying to learn VRay (slow process for someone used to Artlantis, lol)
              how do i get softer shadows?
              i used a "shadow catcher" material for the ground, and the standard sun light..
              and i tryed to play arround with the 'size' and 'subdivs' of the sun light (in the environment tab), but i couldnt get softer shadows...
              i suppose it can be done with dome light or HDRI, but i havnt got to that part yet, lol
              is it possible with the standard sunlight?
              • tademaT Offline
                tadema
                Hello xonpt, Open V-ray output settings, open environment, open the Material Box and under Sunlight you can alter the sun size, bigger the sun the softer the shadows. Hope you can understand this.
                John
                  One of the problems I have noted when using wharehouse models is the use of textures. Some folk rename the standard textures which is fine when you only have one mode/aspect using that mat but a thorough pain when that mat is commonly used elswhere in the scene/set. Other folk will use the same mat for different parts of the same model, the jag here does both of these things. Note the glass is the same mat as the tyres which is a nightmare if your render program treats all instances the same. I doubt roadholding will be great with glass tyres. I will post a renditioner render when I am happy with it.
                  • xonptX Offline
                    xonpt
                    John
                    thank you for the answer, but i actually did just that... and i changed the size from 1.0 to 3.0 and even 12.0, and i always got hard shadows...
                    maybe i've got to give it an even higher value, i will give it a try
                    p.s. - Mike Amos, i totally agree with you, and that's why sometimes one has to spend more time "cleaning" the model than actually rendering it.. but that's part of the "job"..
                    • tademaT Offline
                      tadema
                      Hello xonpt, open a fresh SU and draw a simple base and floor....
                      Sun sizes 01, 10 and 20, can't understand what your doing differently.
                      For checking materials from a Wharehouse model try drawing a cube and paint a face with a bright colour then using Thom Thom's Replace Materials http://sketchucation.com/forums/viewtopic.php?t=26013
                      Your able to swap a material and see whats messed up, replace or hit back button.
                      John
                      • Al HartA Offline
                        Al Hart
                        Oops - this thread has been hijacked.
                        Would you guys mind continuing the discussion of how to use VRay in a new thread?
                        Al Hart
                        • xonptX Offline
                          xonpt
                          hehehe, dont mind at all, but the issue is solved, so there will be no more VRay discussion
                          thanks a lot, Tadema 👍
                          • majidM Offline
                            majid
                            here is my try over tweaked model
                            I wish to have sharp shadows on shadow catcher, but seems there are few tips that I do not lnow, any body here to help?
                            renders using Thea4su
                            • BoxB Offline
                              Are you after photo realistic renders only, or just nice renders?
                              • Al HartA Offline
                                Al Hart
                                We mainly want to encourage people that SketchUp is a good program for both 3D models and nice renderings. So any nice renderings would be helpful.
                                Al Hart
                                  jpalm32
                                  @al hart said:
                                  That's the one I wanted one more vote for.
                                  Lets use it.
                                  Jaguar XKR-S
                                  http://sketchucation.com/forums/download/file.php?id=112725
                                  I am changing the name of this thread, and the link in the first post, etc.
                                  Comes in at over 32 feet for me, need adjustment for good textures
                                  • Al HartA Offline
                                    Al Hart
                                    You're right. Can you scale it down?
                                    Al Hart
                                    • soloS Offline
                                      solo
                                      Another quickie.
                                      http://www.solos-art.com
                                      • soloS Offline
                                        solo
                                        @krisidious said:
                                        here ya go... 108" wheelbase.
                                        http://www.aboveallhouseplans.com/2012-Jaguar-XKR-S.skp
                                        That just goes to your website, no image.
                                          @Al
                                          You have IRender nXt from Render Plus in your signature, why not render your car with it inside SU?
                                          • KrisidiousK Offline
                                            Krisidious
                                            http://www.aboveallhouseplans.com/SU/2012-Jaguar-XKR-S.skp
                                            sorry. fixed.
                                            By: Kristoff Rand
                                            • 2 / 4
