    Keyframe animation and render... same pixel different result
    8 Posts 4 Posters 694 Views 4 Watching
    • D
      decumano
      This is the question, I'm using keyframe animation plug-in with this pixel settings
      and this a frame of the animation
      with the same settings for render the result is this one:
      I started with the render and I would like to get the same view with the animation,
      what should I do? The animation is smaller.
      Thanks everybody!
      • D
        decumano
        ....no one for this question?
        Please, I need help!
        • soloS
          solo
          Sorry friend but I have no solution as I do not use Vray, at this point I'd suggest contacting the author directly from his site but that will not work either as I also have a problem with this plugin and sent an email a month ago to author with no response as of yet. One would think that a commercial plugin would have support.
          http://www.solos-art.com
          • gullfoG
            gullfo
            if the angles are consistent, then cropping may be the answer?
            Glenn
            http://www.runnel.com
            • D
              decumano
              No.... so I have not solutions! I was sure it was a camera problem solvable with a single value or botton!!!
              Cropping... is the answer but not the solution... i'll try to modify camera settings to understand the relation between them
              thank you anyway
              • PixeroP
                Pixero
                Just a guess, have you tried clicking on the "Get view aspect" button?
                • D
                  decumano
                  ..no pixero... it doesn't works: it's because when you export an animation you can choose between 2 options 4:3 or 16:9. So, by clicking "get view aspect" the result doesn't change.
                  Probably the proportion is correct, because 800:450 pixel is the same of 16:9 but camera of the video is too close compared to the render image I got....
                  ..don't konw what to do
                  • D
                    decumano
                    So no one had the same problem and solved it?
                    The problem is not in the rendering settings... the result is similar to the camera view; is the animation different to the camera view...
                    So, should I really cut the render?
