    Sketchup vray problem (mac)
    renderpluginsextensions
    2 Posts 2 Posters 871 Views 2 Watching
    • H
      helvetica
      Vray crashes sketchup, every time. I'm on an iMac i7 with 16gb ram, sketchup make, and the latest vray plugin. As soon as I open su I get a bugsplat crash report. I couldn't reopen as it's opening the same auto saved file and crashing again. Once I remove vray it works fine again, with podium, shaderlight and kerkythea. Anyone else getting this issue? At this stage I have ruled out vray as a render contender!
      • dkendigD
        dkendig
        we would like to examine the scene file and fix the issue if you are able to send it to us, but to work around the issue, you might have luck if you go to system preferences->general, and check the box for "close windows when quitting an application". This ensures that opened docs are not reopened when the app is opened.
        Alternatively, we only attach or plugin to the most recently opened model, so you may have luck opening another su file by double clicking it. The problematic scene file should still load, but we won't attach to it, process it, etc. You should then be able to close it without an issue.
        We have resolved some issues that would cause complex/large scenes to crash in this manner on OSX in a nightly build. If you are interested in testing your issue out in one of those builds, send me a PM.
        Devin Kendig
        Developer
