    [Plugin] TIG-PointUp v1.0 20131120
    8 Posts 5 Posters 4.7k Views 5 Watching
      (c) copyright 2013, TIG
      All Rights Reserved
      THIS SOFTWARE IS PROVIDED "AS IS", WITHOUT ANY EXPRESS OR IMPLIED WARRANTIES, INCLUDING WITHOUT LIMITATION, THE IMPLIED WARRANTIES OF MERCHANTABILITY AND FITNESS FOR A PARTICULAR PURPOSE.
      Usage: Plugins menu > TIG-PointUp
      Pick a point, you are asked to enter a height above that point.
      A number is taken as current model-units but wou can add a units suffix too, so if you are working in mm you can use 1100 or 1.1m to elevate the cpoint etc.
      A cpoint is added at that given elevation [use -ve values if to be below].
      The last used height is remember during that session.
      Repeat as desired...
      Press <space> or choose another tool to stop.
      It undoes each added cpoint in turn.
      Version:
      1.0 20131120 First version.
      Download from the SketchUcation PluginStore
      http://sketchucation.com/resources/pluginstore?pln=TIG-PointUp
      or AutoLoad it from the SketchUcation Plugin Store dialog within SketchUp itself http://sketchucation.com/resources/plugin-store-download
      • CadFatherC Offline
        CadFather
        nice one - thank you TIG, simple... and... to the 'point' . 😛
        • mitcorbM Offline
          mitcorb
          Hi, TIG:
          Does this mean that you pick a point from, say, an array of co-planar cpoints, input the elevation value, and it copies, or moves that cpoint?
            It adds a cpoint elevated as specified above the picked-point.
            The 'point' that you pick [click] can be on a face, vertex, edge or another cpoint.
            There is no 'moving' involved...
              agrazdi
              Is it posible to add an option to be able to select where to add the point to in the 3 axis ?? (Red, Green, Blue )
                Then it won't be PointUp !
                But PointOff ?
                Here it is http://sketchucation.com/forums/viewtopic.php?p=500358#p500358
                  agrazdi
                  Great
                  • utilerU Offline
                    utiler
                    Simply perfect, TIG!!!!! 🎉
                    Thank you so much for taking the time to do this no matter how simple it is; you're a bloody gem!
                    Just Curious...
