    [Plugin] AMS Library 3.7.1b (29 May 2021)
    108 Posts 39 Posters 657.2k Views 39 Watching
      Anton_S
      Opps I forgot to test it on Win XP. Ill check it out.
        Anton_S
        Hello, junaramaro, I made it compatible with Windows XP. Thanks for reporting.
          junaramaro
          Thank you so much sir... šŸ˜„ ...i'm updating now. i really love being in this community of loving and thoughtful persons...
          thank you again master ...may the force be with you... šŸ˜†
          i really think you have to be a jedi to come up with this wonderful things...
          • P Offline
            perroloco2000
            Hello
            Everytime I try to hide menu bar with AMS Window Settings crash my SU 2016. I“m using AMS Window Settings 4.2.0 and AMS Library 3.1.4
            Please help, is really useful optimize my screen when I work on the laptop
            Thanks for your greats plugins
              Anton_S
              Can you downgrade to 3.1.3 and check if the crash still occurs? Here is the download link to 3.1.3: https://drive.google.com/open?id=0B3qg8f4WrNdHci1DLTZEbVpqdzQ
              • P Offline
                perroloco2000
                I had 3.1.3 before, actually I did upgrade to 3.1.4 trying to fix this
                  lionk
                  Hi Anton_S, is there an observer to detect whether the trays in sketchup2016 is automatically shown or hidden, and its width and position?
                    Anton_S
                    Hello lionk,
                    There is no observer that triggers when dialogs/trays are shown or hidden. There is a way, however, to detect if SU2016 trays are visible.
                    Consider the following code snippet to get all visible trays:
                    # Obtain visible trays
                    visible_trays = []
                    AMS;;Sketchup.get_visible_dialogs.each { |handle|
                      cname = AMS;;Window.get_class_name(handle)
                      visible_trays << handle if cname =~ /Afx;ControlBar|Afx;MiniFrame/
                    visible_trays
                    As well as, the following snippet to get all visible trays along with their information, such as title, width, height, and whether its docked or floating:
                    # Get tray information.
                    # Afx;ControlBar resembles a docked tray
                    # Afx;MiniFrame resembles a floating tray
                    tray_data = {}
                      next if cname !~ /Afx;ControlBar|Afx;MiniFrame/
                      rect = AMS;;Window.get_rect(handle)
                      tray_data[handle] = {
                        ;caption => AMS;;Window.get_caption(handle),
                        ;docked  => cname =~ /Afx;ControlBar/ ? true ; false, # docked or floating
                        ;width   => rect[2] - rect[0],
                        ;height  => rect[3] - rect[1]
                    tray_data
                    Anton
                      lionk
                      Thank you!
                      I want to get the status of trays in auto-hide mode, and its size and position, so I can get the accurate width or height of the view. Because the trays will overlap part of the view.
                        atek
                        i have downloaded the zip file containing a folder and .rb file. How to install the plugin
                        • H Offline
                          herojack
                          载兄文件 C:/Users/Administrator/AppData/Roaming/SketchUp/SketchUp 2014/SketchUp/Plugins/ams_Lib/main.rb 时出错
                          Error: #<RuntimeError: can't modify frozen String>
                          D:/Program Files (x86)/SketchUp/SketchUp 2014/Tools/RubyStdLib/rubygems/core_ext/kernel_require.rb:45:in require' D:/Program Files (x86)/SketchUp/SketchUp 2014/Tools/RubyStdLib/rubygems/core_ext/kernel_require.rb:45:in require'
                          C:/Users/Administrator/AppData/Roaming/SketchUp/SketchUp 2014/SketchUp/Plugins/ams_Lib/main.rb:205:in <top (required)>' D:/Program Files (x86)/SketchUp/SketchUp 2014/Tools/extensions.rb:197:in require'
                          D:/Program Files (x86)/SketchUp/SketchUp 2014/Tools/extensions.rb:197:in load' C:/Users/Administrator/AppData/Roaming/SketchUp/SketchUp 2014/SketchUp/Plugins/ams_Lib.rb:47:in register_extension'
                          C:/Users/Administrator/AppData/Roaming/SketchUp/SketchUp 2014/SketchUp/Plugins/ams_Lib.rb:47:in <module:Lib>' C:/Users/Administrator/AppData/Roaming/SketchUp/SketchUp 2014/SketchUp/Plugins/ams_Lib.rb:27:in <top (required)>'
                          • P Offline
                            perroloco2000
                            hi again Anton
                            i have new portatil (with fresh windows 10 install)
                            i“m not able to install AMS library (not 3.2.0. not 3.1.3.). trying with the .rbz by preferencs or extracting .zip in plugins folder same result: crash SU2016 or get the same error as herojack posted
                            any help will be welcome in the way to use your nice plugins
                            thanks
                            Error al cargar archivo C:/Users/XXX/AppData/Roaming/SketchUp/SketchUp 2016/SketchUp/Plugins/ams_Lib/main.rb
                            C:/Program Files/SketchUp/SketchUp 2016/Tools/RubyStdLib/rubygems/core_ext/kernel_require.rb:45:in require' C:/Program Files/SketchUp/SketchUp 2016/Tools/RubyStdLib/rubygems/core_ext/kernel_require.rb:45:in require'
                            C:/Users/XXX/AppData/Roaming/SketchUp/SketchUp 2016/SketchUp/Plugins/ams_Lib/main.rb:205:in <top (required)>' C:/Program Files/SketchUp/SketchUp 2016/Tools/extensions.rb:197:in require'
                            C:/Program Files/SketchUp/SketchUp 2016/Tools/extensions.rb:197:in load' C:/Users/XXX/AppData/Roaming/SketchUp/SketchUp 2016/SketchUp/Plugins/ams_Lib.rb:47:in register_extension'
                            C:/Users/XXX/AppData/Roaming/SketchUp/SketchUp 2016/SketchUp/Plugins/ams_Lib.rb:47:in <module:Lib>' C:/Users/XXX/AppData/Roaming/SketchUp/SketchUp 2016/SketchUp/Plugins/ams_Lib.rb:27:in <top (required)>'
                            • Y Offline
                              ying2014
                              hello Anton_S:
                              I have a question,if I want to set a dialog,and the WedDialogs are on top one more time,but
                              sketchup is activated, in other words,like (dlg.show_modal + AMS::Sketchup.activate),what should I do?
                                Anton_S
                                @Atek to install the plugin, place ams_lib folder and the ams_lib.rb into the plugins folder.
                                The plugins folder is located in the following locations:
                                • For SU8 and below the plugins folder is located in
                                  C:\Program Files (x86)\Google\Google SketchUp [n]\
                                • For SU2013 the plugins folder is located in
                                  C:\Program Files (x86)\SketchUp\SketchUp 2013\
                                • For SU2014+ the plugins folder is located in
                                  C:\Users[User Name]\AppData\Roaming\SketchUp\SketchUp 20XY\SketchUp
                                  I will post these instructions into the main post.
                                @Perojack, @Perroloco2000 I will look into the error. Thanks for reporting.
                                @Ying2014 If I understood you correctly you want to activate the dialog. For that there is an existing function, WebDialog.#bring_to_front. Can you elaborate a bit more if I didn't understand your question?
                                • Y Offline
                                  ying2014
                                  @Anton_s,I want WebDialog to have been in the front until end of a program ,because I want to make the WebDialog as a mask,I can do something to model which I wan't people to see the process. WebDialog.#bring_to_front can't always in the front怂
                                    Anton_S
                                    Here is the code Ying:
                                    title = "My Dialog"
                                    dlg = UI;;WebDialog.new(title)
                                    dlg.show
                                    hwnd = AMS;;Sketchup.find_window_by_caption(title)
                                    AMS;;Window.set_pos(hwnd, -1, 0,0,0,0, 0x0023) # The -1 here does the trick
                                    Though upgrade to 3.2.1 first as there was a small bug in that function.
                                    @Perojack, @Perroloco2000 I think the error is fixed now. Try the new version.
                                    • Y Offline
                                      ying2014
                                      @Anton_S,thank you very much!It is helpful.
                                      • P Offline
                                        perroloco2000
                                        thanks for answer Anton
                                        AMS Library 3.2.1. is working, no error
                                        But I still have my past problem with AMS Window Settings: everytime i hide menu bar crash SU.
                                        The others functions of the plugin are working but impossible hide menu bar without crash.
                                        please help to optimize my screen
                                          Anton_S
                                          @Perroloco2000 give me a list of plugins your using, a list of shortcuts (Preferences->Shortcuts->Export...), sketchup version, sketchup localization (en, fr, or whatever) and windows version so that I could attempt to reproduce the crash and pin it down on my own machine.
                                          • P Offline
                                            perroloco2000
                                            SketchUp Make 2016 16.1.1449 64-bits (spanish). Windows 10 Home 1511 (10586.164)
                                            I have a fresh install of windows 10 (last version) and SketchUp (last version). I still haven“t other plugins, and didn“t modify default shortcuts.
                                            I installed AMS Library 3.2.1. (all works)
                                            I installed AMS Window Settings 4.2.0. all functions works but when I hide menu bar the crash come. Thanks
                                            • 6
                                            • 3 / 6
