    [Plugin] AMS Library 3.7.1b (29 May 2021)
    108 Posts 39 Posters 686.2k Views 39 Watching
      Anton_S
      Hello, junaramaro, I made it compatible with Windows XP. Thanks for reporting.
        junaramaro
        Thank you so much sir... 😄 ...i'm updating now. i really love being in this community of loving and thoughtful persons...
        thank you again master ...may the force be with you... 😆
        i really think you have to be a jedi to come up with this wonderful things...
        • P
          perroloco2000
          Hello
          Everytime I try to hide menu bar with AMS Window Settings crash my SU 2016. I´m using AMS Window Settings 4.2.0 and AMS Library 3.1.4
          Please help, is really useful optimize my screen when I work on the laptop
          Thanks for your greats plugins
            Anton_S
            Can you downgrade to 3.1.3 and check if the crash still occurs? Here is the download link to 3.1.3: https://drive.google.com/open?id=0B3qg8f4WrNdHci1DLTZEbVpqdzQ
            • P
              perroloco2000
              I had 3.1.3 before, actually I did upgrade to 3.1.4 trying to fix this
              • L
                lionk
                Hi Anton_S, is there an observer to detect whether the trays in sketchup2016 is automatically shown or hidden, and its width and position?
                  Anton_S
                  Hello lionk,
                  There is no observer that triggers when dialogs/trays are shown or hidden. There is a way, however, to detect if SU2016 trays are visible.
                  Consider the following code snippet to get all visible trays:
                  # Obtain visible trays
                  visible_trays = []
                  AMS;;Sketchup.get_visible_dialogs.each { |handle|
                    cname = AMS;;Window.get_class_name(handle)
                    visible_trays << handle if cname =~ /Afx;ControlBar|Afx;MiniFrame/
                  visible_trays
                  As well as, the following snippet to get all visible trays along with their information, such as title, width, height, and whether its docked or floating:
                  # Get tray information.
                  # Afx;ControlBar resembles a docked tray
                  # Afx;MiniFrame resembles a floating tray
                  tray_data = {}
                    next if cname !~ /Afx;ControlBar|Afx;MiniFrame/
                    rect = AMS;;Window.get_rect(handle)
                    tray_data[handle] = {
                      ;caption => AMS;;Window.get_caption(handle),
                      ;docked  => cname =~ /Afx;ControlBar/ ? true ; false, # docked or floating
                      ;width   => rect[2] - rect[0],
                      ;height  => rect[3] - rect[1]
                  tray_data
                  Anton
                  • L
                    lionk
                    Thank you!
                    I want to get the status of trays in auto-hide mode, and its size and position, so I can get the accurate width or height of the view. Because the trays will overlap part of the view.
                      atek
                      i have downloaded the zip file containing a folder and .rb file. How to install the plugin
                      • H
                        herojack
                        载入文件 C:/Users/Administrator/AppData/Roaming/SketchUp/SketchUp 2014/SketchUp/Plugins/ams_Lib/main.rb 时出错
                        Error: #<RuntimeError: can't modify frozen String>
                        D:/Program Files (x86)/SketchUp/SketchUp 2014/Tools/RubyStdLib/rubygems/core_ext/kernel_require.rb:45:in require' D:/Program Files (x86)/SketchUp/SketchUp 2014/Tools/RubyStdLib/rubygems/core_ext/kernel_require.rb:45:in require'
                        C:/Users/Administrator/AppData/Roaming/SketchUp/SketchUp 2014/SketchUp/Plugins/ams_Lib/main.rb:205:in <top (required)>' D:/Program Files (x86)/SketchUp/SketchUp 2014/Tools/extensions.rb:197:in require'
                        D:/Program Files (x86)/SketchUp/SketchUp 2014/Tools/extensions.rb:197:in load' C:/Users/Administrator/AppData/Roaming/SketchUp/SketchUp 2014/SketchUp/Plugins/ams_Lib.rb:47:in register_extension'
                        C:/Users/Administrator/AppData/Roaming/SketchUp/SketchUp 2014/SketchUp/Plugins/ams_Lib.rb:47:in <module:Lib>' C:/Users/Administrator/AppData/Roaming/SketchUp/SketchUp 2014/SketchUp/Plugins/ams_Lib.rb:27:in <top (required)>'
                        • P
                          perroloco2000
                          hi again Anton
                          i have new portatil (with fresh windows 10 install)
                          i´m not able to install AMS library (not 3.2.0. not 3.1.3.). trying with the .rbz by preferencs or extracting .zip in plugins folder same result: crash SU2016 or get the same error as herojack posted
                          any help will be welcome in the way to use your nice plugins
                          thanks
                          Error al cargar archivo C:/Users/XXX/AppData/Roaming/SketchUp/SketchUp 2016/SketchUp/Plugins/ams_Lib/main.rb
                          C:/Program Files/SketchUp/SketchUp 2016/Tools/RubyStdLib/rubygems/core_ext/kernel_require.rb:45:in require' C:/Program Files/SketchUp/SketchUp 2016/Tools/RubyStdLib/rubygems/core_ext/kernel_require.rb:45:in require'
                          C:/Users/XXX/AppData/Roaming/SketchUp/SketchUp 2016/SketchUp/Plugins/ams_Lib/main.rb:205:in <top (required)>' C:/Program Files/SketchUp/SketchUp 2016/Tools/extensions.rb:197:in require'
                          C:/Program Files/SketchUp/SketchUp 2016/Tools/extensions.rb:197:in load' C:/Users/XXX/AppData/Roaming/SketchUp/SketchUp 2016/SketchUp/Plugins/ams_Lib.rb:47:in register_extension'
                          C:/Users/XXX/AppData/Roaming/SketchUp/SketchUp 2016/SketchUp/Plugins/ams_Lib.rb:47:in <module:Lib>' C:/Users/XXX/AppData/Roaming/SketchUp/SketchUp 2016/SketchUp/Plugins/ams_Lib.rb:27:in <top (required)>'
                          • Y
                            ying2014
                            hello Anton_S:
                            I have a question,if I want to set a dialog,and the WedDialogs are on top one more time,but
                            sketchup is activated, in other words,like (dlg.show_modal + AMS::Sketchup.activate),what should I do?
                              Anton_S
                              @Atek to install the plugin, place ams_lib folder and the ams_lib.rb into the plugins folder.
                              The plugins folder is located in the following locations:
                              • For SU8 and below the plugins folder is located in
                                C:\Program Files (x86)\Google\Google SketchUp [n]\
                              • For SU2013 the plugins folder is located in
                                C:\Program Files (x86)\SketchUp\SketchUp 2013\
                              • For SU2014+ the plugins folder is located in
                                C:\Users[User Name]\AppData\Roaming\SketchUp\SketchUp 20XY\SketchUp
                                I will post these instructions into the main post.
                              @Perojack, @Perroloco2000 I will look into the error. Thanks for reporting.
                              @Ying2014 If I understood you correctly you want to activate the dialog. For that there is an existing function, WebDialog.#bring_to_front. Can you elaborate a bit more if I didn't understand your question?
                              • Y
                                ying2014
                                @Anton_s,I want WebDialog to have been in the front until end of a program ,because I want to make the WebDialog as a mask,I can do something to model which I wan't people to see the process. WebDialog.#bring_to_front can't always in the front。
                                  Anton_S
                                  Here is the code Ying:
                                  title = "My Dialog"
                                  dlg = UI;;WebDialog.new(title)
                                  dlg.show
                                  hwnd = AMS;;Sketchup.find_window_by_caption(title)
                                  AMS;;Window.set_pos(hwnd, -1, 0,0,0,0, 0x0023) # The -1 here does the trick
                                  Though upgrade to 3.2.1 first as there was a small bug in that function.
                                  @Perojack, @Perroloco2000 I think the error is fixed now. Try the new version.
                                  • Y
                                    ying2014
                                    @Anton_S,thank you very much!It is helpful.
                                    • P
                                      perroloco2000
                                      thanks for answer Anton
                                      AMS Library 3.2.1. is working, no error
                                      But I still have my past problem with AMS Window Settings: everytime i hide menu bar crash SU.
                                      The others functions of the plugin are working but impossible hide menu bar without crash.
                                      please help to optimize my screen
                                        Anton_S
                                        @Perroloco2000 give me a list of plugins your using, a list of shortcuts (Preferences->Shortcuts->Export...), sketchup version, sketchup localization (en, fr, or whatever) and windows version so that I could attempt to reproduce the crash and pin it down on my own machine.
                                        • P
                                          perroloco2000
                                          SketchUp Make 2016 16.1.1449 64-bits (spanish). Windows 10 Home 1511 (10586.164)
                                          I have a fresh install of windows 10 (last version) and SketchUp (last version). I still haven´t other plugins, and didn´t modify default shortcuts.
                                          I installed AMS Library 3.2.1. (all works)
                                          I installed AMS Window Settings 4.2.0. all functions works but when I hide menu bar the crash come. Thanks
                                            Anton_S
                                            Ok I am able to reproduce it with Spanish localization. I even get frozen strings errors, which I have no idea what's causing them and how to prevent them. I will look into into it and do my best to fix it.
                                            • 3 / 6
