    [Plugin] AMS Library 3.7.1b (29 May 2021)
    108 Posts 39 Posters 686.2k Views 39 Watching
      Anton_S
      Hello everyone, AMS Library version 3.1.1 has been released. It is important to upgrade to a new version because it addresses a bug fix, which caused spike in performance, which lead to toolbar icons staying highlighted and eventually to a crash. Huge thanks to Pherim for reporting and verifying it. See first post for download links.
      • P
        Pherim
        Thanks again for fixing it!
          junaramaro
          i think it no longer has a support for xp...it shows some error 😐 ...sorry i forgot to post some pics...but it really does.i hope some xp users show the error..but i'll post it soon...or maybe its a bug...please dont stop the support for xp unlike microsoft...this is a really great plugin with lots of possibilities.... 😉
            Anton_S
            Opps I forgot to test it on Win XP. Ill check it out.
              Anton_S
              Hello, junaramaro, I made it compatible with Windows XP. Thanks for reporting.
                junaramaro
                Thank you so much sir... 😄 ...i'm updating now. i really love being in this community of loving and thoughtful persons...
                thank you again master ...may the force be with you... 😆
                i really think you have to be a jedi to come up with this wonderful things...
                • P
                  perroloco2000
                  Hello
                  Everytime I try to hide menu bar with AMS Window Settings crash my SU 2016. I´m using AMS Window Settings 4.2.0 and AMS Library 3.1.4
                  Please help, is really useful optimize my screen when I work on the laptop
                  Thanks for your greats plugins
                    Anton_S
                    Can you downgrade to 3.1.3 and check if the crash still occurs? Here is the download link to 3.1.3: https://drive.google.com/open?id=0B3qg8f4WrNdHci1DLTZEbVpqdzQ
                    • P
                      perroloco2000
                      I had 3.1.3 before, actually I did upgrade to 3.1.4 trying to fix this
                      • L
                        lionk
                        Hi Anton_S, is there an observer to detect whether the trays in sketchup2016 is automatically shown or hidden, and its width and position?
                          Anton_S
                          Hello lionk,
                          There is no observer that triggers when dialogs/trays are shown or hidden. There is a way, however, to detect if SU2016 trays are visible.
                          Consider the following code snippet to get all visible trays:
                          # Obtain visible trays
                          visible_trays = []
                          AMS;;Sketchup.get_visible_dialogs.each { |handle|
                            cname = AMS;;Window.get_class_name(handle)
                            visible_trays << handle if cname =~ /Afx;ControlBar|Afx;MiniFrame/
                          visible_trays
                          As well as, the following snippet to get all visible trays along with their information, such as title, width, height, and whether its docked or floating:
                          # Get tray information.
                          # Afx;ControlBar resembles a docked tray
                          # Afx;MiniFrame resembles a floating tray
                          tray_data = {}
                            next if cname !~ /Afx;ControlBar|Afx;MiniFrame/
                            rect = AMS;;Window.get_rect(handle)
                            tray_data[handle] = {
                              ;caption => AMS;;Window.get_caption(handle),
                              ;docked  => cname =~ /Afx;ControlBar/ ? true ; false, # docked or floating
                              ;width   => rect[2] - rect[0],
                              ;height  => rect[3] - rect[1]
                          tray_data
                          Anton
                          • L
                            lionk
                            Thank you!
                            I want to get the status of trays in auto-hide mode, and its size and position, so I can get the accurate width or height of the view. Because the trays will overlap part of the view.
                              atek
                              i have downloaded the zip file containing a folder and .rb file. How to install the plugin
                              • H
                                herojack
                                载入文件 C:/Users/Administrator/AppData/Roaming/SketchUp/SketchUp 2014/SketchUp/Plugins/ams_Lib/main.rb 时出错
                                Error: #<RuntimeError: can't modify frozen String>
                                D:/Program Files (x86)/SketchUp/SketchUp 2014/Tools/RubyStdLib/rubygems/core_ext/kernel_require.rb:45:in require' D:/Program Files (x86)/SketchUp/SketchUp 2014/Tools/RubyStdLib/rubygems/core_ext/kernel_require.rb:45:in require'
                                C:/Users/Administrator/AppData/Roaming/SketchUp/SketchUp 2014/SketchUp/Plugins/ams_Lib/main.rb:205:in <top (required)>' D:/Program Files (x86)/SketchUp/SketchUp 2014/Tools/extensions.rb:197:in require'
                                D:/Program Files (x86)/SketchUp/SketchUp 2014/Tools/extensions.rb:197:in load' C:/Users/Administrator/AppData/Roaming/SketchUp/SketchUp 2014/SketchUp/Plugins/ams_Lib.rb:47:in register_extension'
                                C:/Users/Administrator/AppData/Roaming/SketchUp/SketchUp 2014/SketchUp/Plugins/ams_Lib.rb:47:in <module:Lib>' C:/Users/Administrator/AppData/Roaming/SketchUp/SketchUp 2014/SketchUp/Plugins/ams_Lib.rb:27:in <top (required)>'
                                • P
                                  perroloco2000
                                  hi again Anton
                                  i have new portatil (with fresh windows 10 install)
                                  i´m not able to install AMS library (not 3.2.0. not 3.1.3.). trying with the .rbz by preferencs or extracting .zip in plugins folder same result: crash SU2016 or get the same error as herojack posted
                                  any help will be welcome in the way to use your nice plugins
                                  thanks
                                  Error al cargar archivo C:/Users/XXX/AppData/Roaming/SketchUp/SketchUp 2016/SketchUp/Plugins/ams_Lib/main.rb
                                  C:/Program Files/SketchUp/SketchUp 2016/Tools/RubyStdLib/rubygems/core_ext/kernel_require.rb:45:in require' C:/Program Files/SketchUp/SketchUp 2016/Tools/RubyStdLib/rubygems/core_ext/kernel_require.rb:45:in require'
                                  C:/Users/XXX/AppData/Roaming/SketchUp/SketchUp 2016/SketchUp/Plugins/ams_Lib/main.rb:205:in <top (required)>' C:/Program Files/SketchUp/SketchUp 2016/Tools/extensions.rb:197:in require'
                                  C:/Program Files/SketchUp/SketchUp 2016/Tools/extensions.rb:197:in load' C:/Users/XXX/AppData/Roaming/SketchUp/SketchUp 2016/SketchUp/Plugins/ams_Lib.rb:47:in register_extension'
                                  C:/Users/XXX/AppData/Roaming/SketchUp/SketchUp 2016/SketchUp/Plugins/ams_Lib.rb:47:in <module:Lib>' C:/Users/XXX/AppData/Roaming/SketchUp/SketchUp 2016/SketchUp/Plugins/ams_Lib.rb:27:in <top (required)>'
                                  • Y
                                    ying2014
                                    hello Anton_S:
                                    I have a question,if I want to set a dialog,and the WedDialogs are on top one more time,but
                                    sketchup is activated, in other words,like (dlg.show_modal + AMS::Sketchup.activate),what should I do?
                                      Anton_S
                                      @Atek to install the plugin, place ams_lib folder and the ams_lib.rb into the plugins folder.
                                      The plugins folder is located in the following locations:
                                      • For SU8 and below the plugins folder is located in
                                        C:\Program Files (x86)\Google\Google SketchUp [n]\
                                      • For SU2013 the plugins folder is located in
                                        C:\Program Files (x86)\SketchUp\SketchUp 2013\
                                      • For SU2014+ the plugins folder is located in
                                        C:\Users[User Name]\AppData\Roaming\SketchUp\SketchUp 20XY\SketchUp
                                        I will post these instructions into the main post.
                                      @Perojack, @Perroloco2000 I will look into the error. Thanks for reporting.
                                      @Ying2014 If I understood you correctly you want to activate the dialog. For that there is an existing function, WebDialog.#bring_to_front. Can you elaborate a bit more if I didn't understand your question?
                                      • Y
                                        ying2014
                                        @Anton_s,I want WebDialog to have been in the front until end of a program ,because I want to make the WebDialog as a mask,I can do something to model which I wan't people to see the process. WebDialog.#bring_to_front can't always in the front。
                                          Anton_S
                                          Here is the code Ying:
                                          title = "My Dialog"
                                          dlg = UI;;WebDialog.new(title)
                                          dlg.show
                                          hwnd = AMS;;Sketchup.find_window_by_caption(title)
                                          AMS;;Window.set_pos(hwnd, -1, 0,0,0,0, 0x0023) # The -1 here does the trick
                                          Though upgrade to 3.2.1 first as there was a small bug in that function.
                                          @Perojack, @Perroloco2000 I think the error is fixed now. Try the new version.
                                          • Y
                                            ying2014
                                            @Anton_S,thank you very much!It is helpful.
                                            • 3 / 6
