    [Plugin] AMS Library 3.7.1b (29 May 2021)
    108 Posts 39 Posters 686.2k Views 39 Watching
    • P
      Pherim
      I'm afraid it still happens... I was just able to reproduce it two times, using only standard tools.
        Anton_S
        Good! Looks like you know the exact steps to reproduce it. List 'em here, please.
        • P
          Pherim
          Well there is not much more to it than I already wrote. I just use various tools, make groups and components and edit them, until the tools begin to stay highlighted in the toolbar - this happens all the time. Then, at some point, it eventually crashes when I right-click, possibly only or at least more often on groups or components. I tried to record a video of the process, but so far, I have not been able to produce a crash while recording. Maybe they are not happening as often now, but they definitely still do.
            Anton_S
            Hello everyone, AMS Library version 3.1.1 has been released. It is important to upgrade to a new version because it addresses a bug fix, which caused spike in performance, which lead to toolbar icons staying highlighted and eventually to a crash. Huge thanks to Pherim for reporting and verifying it. See first post for download links.
            • P
              Pherim
              Thanks again for fixing it!
                junaramaro
                i think it no longer has a support for xp...it shows some error 😐 ...sorry i forgot to post some pics...but it really does.i hope some xp users show the error..but i'll post it soon...or maybe its a bug...please dont stop the support for xp unlike microsoft...this is a really great plugin with lots of possibilities.... 😉
                  Anton_S
                  Opps I forgot to test it on Win XP. Ill check it out.
                    Anton_S
                    Hello, junaramaro, I made it compatible with Windows XP. Thanks for reporting.
                      junaramaro
                      Thank you so much sir... 😄 ...i'm updating now. i really love being in this community of loving and thoughtful persons...
                      thank you again master ...may the force be with you... 😆
                      i really think you have to be a jedi to come up with this wonderful things...
                      • P
                        perroloco2000
                        Hello
                        Everytime I try to hide menu bar with AMS Window Settings crash my SU 2016. I´m using AMS Window Settings 4.2.0 and AMS Library 3.1.4
                        Please help, is really useful optimize my screen when I work on the laptop
                        Thanks for your greats plugins
                          Anton_S
                          Can you downgrade to 3.1.3 and check if the crash still occurs? Here is the download link to 3.1.3: https://drive.google.com/open?id=0B3qg8f4WrNdHci1DLTZEbVpqdzQ
                          • P
                            perroloco2000
                            I had 3.1.3 before, actually I did upgrade to 3.1.4 trying to fix this
                            • L
                              lionk
                              Hi Anton_S, is there an observer to detect whether the trays in sketchup2016 is automatically shown or hidden, and its width and position?
                                Anton_S
                                Hello lionk,
                                There is no observer that triggers when dialogs/trays are shown or hidden. There is a way, however, to detect if SU2016 trays are visible.
                                Consider the following code snippet to get all visible trays:
                                # Obtain visible trays
                                visible_trays = []
                                AMS;;Sketchup.get_visible_dialogs.each { |handle|
                                  cname = AMS;;Window.get_class_name(handle)
                                  visible_trays << handle if cname =~ /Afx;ControlBar|Afx;MiniFrame/
                                visible_trays
                                As well as, the following snippet to get all visible trays along with their information, such as title, width, height, and whether its docked or floating:
                                # Get tray information.
                                # Afx;ControlBar resembles a docked tray
                                # Afx;MiniFrame resembles a floating tray
                                tray_data = {}
                                  next if cname !~ /Afx;ControlBar|Afx;MiniFrame/
                                  rect = AMS;;Window.get_rect(handle)
                                  tray_data[handle] = {
                                    ;caption => AMS;;Window.get_caption(handle),
                                    ;docked  => cname =~ /Afx;ControlBar/ ? true ; false, # docked or floating
                                    ;width   => rect[2] - rect[0],
                                    ;height  => rect[3] - rect[1]
                                tray_data
                                Anton
                                • L
                                  lionk
                                  Thank you!
                                  I want to get the status of trays in auto-hide mode, and its size and position, so I can get the accurate width or height of the view. Because the trays will overlap part of the view.
                                    atek
                                    i have downloaded the zip file containing a folder and .rb file. How to install the plugin
                                    • H
                                      herojack
                                      载入文件 C:/Users/Administrator/AppData/Roaming/SketchUp/SketchUp 2014/SketchUp/Plugins/ams_Lib/main.rb 时出错
                                      Error: #<RuntimeError: can't modify frozen String>
                                      D:/Program Files (x86)/SketchUp/SketchUp 2014/Tools/RubyStdLib/rubygems/core_ext/kernel_require.rb:45:in require' D:/Program Files (x86)/SketchUp/SketchUp 2014/Tools/RubyStdLib/rubygems/core_ext/kernel_require.rb:45:in require'
                                      C:/Users/Administrator/AppData/Roaming/SketchUp/SketchUp 2014/SketchUp/Plugins/ams_Lib/main.rb:205:in <top (required)>' D:/Program Files (x86)/SketchUp/SketchUp 2014/Tools/extensions.rb:197:in require'
                                      D:/Program Files (x86)/SketchUp/SketchUp 2014/Tools/extensions.rb:197:in load' C:/Users/Administrator/AppData/Roaming/SketchUp/SketchUp 2014/SketchUp/Plugins/ams_Lib.rb:47:in register_extension'
                                      C:/Users/Administrator/AppData/Roaming/SketchUp/SketchUp 2014/SketchUp/Plugins/ams_Lib.rb:47:in <module:Lib>' C:/Users/Administrator/AppData/Roaming/SketchUp/SketchUp 2014/SketchUp/Plugins/ams_Lib.rb:27:in <top (required)>'
                                      • P
                                        perroloco2000
                                        hi again Anton
                                        i have new portatil (with fresh windows 10 install)
                                        i´m not able to install AMS library (not 3.2.0. not 3.1.3.). trying with the .rbz by preferencs or extracting .zip in plugins folder same result: crash SU2016 or get the same error as herojack posted
                                        any help will be welcome in the way to use your nice plugins
                                        thanks
                                        Error al cargar archivo C:/Users/XXX/AppData/Roaming/SketchUp/SketchUp 2016/SketchUp/Plugins/ams_Lib/main.rb
                                        C:/Program Files/SketchUp/SketchUp 2016/Tools/RubyStdLib/rubygems/core_ext/kernel_require.rb:45:in require' C:/Program Files/SketchUp/SketchUp 2016/Tools/RubyStdLib/rubygems/core_ext/kernel_require.rb:45:in require'
                                        C:/Users/XXX/AppData/Roaming/SketchUp/SketchUp 2016/SketchUp/Plugins/ams_Lib/main.rb:205:in <top (required)>' C:/Program Files/SketchUp/SketchUp 2016/Tools/extensions.rb:197:in require'
                                        C:/Program Files/SketchUp/SketchUp 2016/Tools/extensions.rb:197:in load' C:/Users/XXX/AppData/Roaming/SketchUp/SketchUp 2016/SketchUp/Plugins/ams_Lib.rb:47:in register_extension'
                                        C:/Users/XXX/AppData/Roaming/SketchUp/SketchUp 2016/SketchUp/Plugins/ams_Lib.rb:47:in <module:Lib>' C:/Users/XXX/AppData/Roaming/SketchUp/SketchUp 2016/SketchUp/Plugins/ams_Lib.rb:27:in <top (required)>'
                                        • Y
                                          ying2014
                                          hello Anton_S:
                                          I have a question,if I want to set a dialog,and the WedDialogs are on top one more time,but
                                          sketchup is activated, in other words,like (dlg.show_modal + AMS::Sketchup.activate),what should I do?
                                            Anton_S
                                            @Atek to install the plugin, place ams_lib folder and the ams_lib.rb into the plugins folder.
                                            The plugins folder is located in the following locations:
                                            • For SU8 and below the plugins folder is located in
                                              C:\Program Files (x86)\Google\Google SketchUp [n]\
                                            • For SU2013 the plugins folder is located in
                                              C:\Program Files (x86)\SketchUp\SketchUp 2013\
                                            • For SU2014+ the plugins folder is located in
                                              C:\Users[User Name]\AppData\Roaming\SketchUp\SketchUp 20XY\SketchUp
                                              I will post these instructions into the main post.
                                            @Perojack, @Perroloco2000 I will look into the error. Thanks for reporting.
                                            @Ying2014 If I understood you correctly you want to activate the dialog. For that there is an existing function, WebDialog.#bring_to_front. Can you elaborate a bit more if I didn't understand your question?
                                            • 3 / 6
