    How to add new object to a component
    5 Posts 2 Posters 588 Views 2 Watching
    • E
      erzane
      I would like to add a brand new object (or another component) to an actual component without breaking this last one, and without having 2 components, or a group.
      In fact, what I would like to do is a kind of fusion of my actual component, and the new object.
      thanks
        Easy enough. I would start by locating the new component or entity in the desired location while the other component is NOT open for editing. Then you will use Edit>Cut on the new component, open the other component for editing and hit Edit>Paste in place. Since you don't want two components, explode the new component either before using Edit>Cut or after Edit>Paste in place. It doesn't matter much when you do it.
        If your new component was assigned to a layer other than Layer 0, the geometry will get that layer association when you explode the component so don't forget to set the layer assignment back to Layer 0 while all that geometry is still selected.
        Depending on the circumstances, you may also need to perform an Intersect Faces operation and delete the unwanted or unneeded geometry.
        • E
          erzane
          great!
          it sounds good, thanks
          p.s. about the layer
          I never use layer, so no need to do anything with that ?
            Nope. If you don't make any additional layers, you don't have to worry about that.
            • E
              erzane
              ok
              mission succeed
              thanks
