    Move selection - relative to current position/coordinate VCB
    5 Posts 4 Posters 412 Views 4 Watching
    • G Offline
      gamber
      I am looking for simple way/plugin to move a selected item to a new coordinate on a face, relative to it's current position with the VCB box.
      Essentially, I envision the workflow as follows:
      • activate the tool
      • select the object
      • move object on the face (with results showing up in the VCB box)
      • release object, and finally
      • update exact location via VCB box
      As a reference, this would be similar to the TF Peg tool by Clark Bremer, but applicable to any object.
      Does anyone know of any method/plugin to achieve this?
      Thanks in advance,
      • BoxB Offline
        The standard move tool.
        Start it moving and type a distance or co-ordinates and hit enter.
        distance as in 12m enter
        or <50,20,100> enter
        • gillesG Offline
          gilles
          Box said it.
          Read the manual:
          ➡ http://help.sketchup.com/en/article/94863
          • G Offline
            gamber
            Manual has been read, and yes, this is a work around. Have you tried the tool I referred to? If so, that will show you more precisely what I am looking for.
              Entering values in the VCB is how you make changes using the native tools. That's not a work around.
