    Detached house project
    31 Posts 12 Posters 4.6k Views 12 Watching
    • CarlohC Offline
      Carloh
      this i an university project where the goal is to practice your visualisation skills...at the end there should be an animation from the whole site. for the garden there are not many specifications, so i'm looking forward to build it πŸ˜„
      i think i will go pretty deep into detailing this, so there will be some updates.
      here are two currant renders of what i built this far (Thea Render).
        jpalm32
        Nice start.
        Are gutter down pipes really that far from walls there?
        • Bryan KB Offline
          More detail? It looks to me like all you need is the garden and it's done. πŸ‘ πŸ˜„
          Great renders.
          • CarlohC Offline
            Carloh
            thank you guys for your comments! πŸ˜„
            that's a good hint for the gutter pipes, i guess i will move them closer to the walls. πŸ‘
            More detailing to the house will mean here, that i'll build an interior, because as you see i want to have a dusk scene with interior lights on, so i want to show something inside the house. πŸ˜„
              ArCAD-UK
              Your rainwater pipes look quite big for such a small roof, unless you live in a monsoon district. There's no reason why you can't have the pipes away from the wall as long as they are self-supporting or suitably braced. If you go down that route I would make them look like they are supporting the roof.
              The downstairs ceiling looks like it is on fire! It might not look so bad once you have landscape reflections as well.
              Good start πŸ‘
              • DanielD Offline
                Daniel
                Nice wall texture. Be careful where you crop your images - on the first one, the very tip of the roof is cut off (on the left).
                My avatar is an anachronism.
                • CarlohC Offline
                  Carloh
                  thanks for your hint Daniel! I'll keep that in mind for the next renders! πŸ˜„
                  • CarlohC Offline
                    Carloh
                    ...just added some more lighting to the scene. β˜€
                    • CarlohC Offline
                      Carloh
                      ...what to do when you lack the motivation to model? Right...you render! πŸ˜„
                      just testing some different IBL images for the scene and playing with the lighting parts here...
                      • Bryan KB Offline
                        Looking good. πŸ‘
                        • CarlohC Offline
                          Carloh
                          ...some more environment testing πŸ˜„
                          • CarlohC Offline
                            Carloh
                            some model progress...and since i'm new to thea i'm testing all the possible render settings...this time no GPU render, instead had a go with unbiased TR 2.
                            • tademaT Offline
                              tadema
                              Looking great Carloh especially the last one πŸ‘
                              John
                              • CarlohC Offline
                                Carloh
                                thank you John for the kind words! that's nice to read especially by a master like you πŸ˜„
                                • Bryan KB Offline
                                  Oh wow.
                                  And you say it isn't finished? πŸ˜„
                                  • FrederikF Offline
                                    Frederik
                                    I've already commented on the last one on the Thea Render forum, but guess it doesn't hurt to post here as well... πŸ˜„
                                    One thing...
                                    Can you share the technique you've used to create the big emitting glass bowls in the below render...?
                                    Or perhaps you can even share a render ready 'skippy'...? πŸ˜„
                                    http://sketchucation.com/forums/download/file.php?id=112025&mode=view/rokbox.jpg
                                    Cheers
                                    Kim Frederik
                                      Very nice Carloh but steady on, it's possible to go right off someone THAT good....... πŸ‘
                                      • CarlohC Offline
                                        Carloh
                                        Erm...i have to admit that this is the first time here that my english skills leave me in the dark...all i get from this sentence is the thumbs up, so thanks for that πŸ˜„
                                        @frederik said:
                                        One thing...
                                        Of course...there's not much magic in these. it's just a sphere i got from the warehouse, put it through artisan to get a smoother surface and then stretched them a little with the scale tool to have a kind of ellipsoid body. the material is a standard frosted glass from the thea library and inside is a point light. anyways here's a thea scene you can use and modify for your needs πŸ˜„
                                        lichtkugeln.zip
                                        • olisheaO Offline
                                          olishea
                                          Your last render beat me to it, but I'll comment anyway....
                                          When using IBL to illuminate a scene, it's always 100% more realistic to add some entourage between the subject foreground and background. You can see in your previous renders that the world just ends and a background appears, making the scene appear computer generated. Even something as simple as a tree line, some bushes, a garden wall etc. can all break up the line between foreground and background, allowing for a much more realistic scene.
                                          So basically for a scene of this type you need:
                                          1)Foreground entourage
                                          2)Foreground
                                          3)Subject
                                          4)Subject background entourage
                                          5)Background
                                          Instead of: (which looks unrealistic)
                                          1)Foreground
                                          2)Subject
                                          3)Background
                                          Your last render does compensate for this, but I thought I'd share my views anyway. πŸ‘
                                          oli
                                          • FrederikF Offline
                                            Frederik
                                            Thanks for sharing, Carloh... πŸ‘
                                            So the secret was the standard frosted glass from the Thea material library...
                                            I had tried different materials, but couldn't find any I was happy with...
                                            Cheers
                                            Kim Frederik
                                            • 1 / 2
