    [HELP] Lighting rendering trouble
    renderpluginsextensions
    4 Posts 2 Posters 417 Views 2 Watching
      alvinhy
      Hello Everyone,
      I have a problem with rendering in Vray. The draft rendering with materials override looks normal. But when doing a full render with materials, the render becomes white.
      Any idea what is happening or if there is a fix to this problem?
      Thanks in advance!
      Without materials:
      http://thumbnails107.imagebam.com/28694/8593eb286932778.jpg
      With Materials:
      http://thumbnails106.imagebam.com/28694/d2f788286938815.jpg
      • V Offline
        valerostudio
        My first guess is you have a material that has an emitter layer and its blowing out the render. When you click override that emitter material is not casting light.
          alvinhy
          Hello valerostudio, I just set the default settings in vray options and did a render. The lighting came out fine. I guess it is some settings inside the options that made the light so bright.
          Are there any good settings I can use to have a high quality render?
          • V Offline
            valerostudio
            If you are using 2.0 there are presets for interiors. They work very well.
