    Sketchup and Blender
    extensions
    170 Posts 26 Posters 48.6k Views 26 Watching
      Winner.
      Show the blender mesh.
      Mine way to quickly learn commands is with the dynamic menu. Hit space bar while in the viewport and start typing.
      • soloS Offline
        solo
        @rich o brien said:
        Winner.
        What is supposed to happen when you hit space, I get a window that opens but not sure what to do then.
        Here is the screen shot.
        http://www.solos-art.com
          You should see this command palette...
          ...here you can type a word to see what the command is...
          example...if you needed to merge verts hit space - type merge...
          ...and you'll see the command is Alt+M
          Great way to learn what is the shortcuts and the commands.
          I'd really like to see the Thea Logo in edit mode.
          Select it, hit edit and then hit / on the numpad to go into local view.
          Take a screengrab while in edit mode so we can see the mesh.
          • andybotA Offline
            andybot
            Woohoo!! Thanks for starting this thread Pete, glad to see Rich and Michalis right on board! I will be watching and participating as I can. I ❀ Blender!
            • andybotA Offline
              andybot
              My tool of choice in SU is TIG's "Triangulate Faces" plugin. Before exporting anything to Blender that I will be editing in Blender, I always make sure I can see the entirety of my topology, and then make extensive use of the sandbox "Flip Edge" tool. I use TIG's obj exporter for my conversion, then import with the "keep vert order" option. (This is important for vray proxies, plus it helps keep the outliner neater.) Then in Blender: Mesh -> vertices - > "remove doubles", and Alt-J for tris to Quads.
              • soloS Offline
                solo
                I inserted it into post above, not much done to it from export, I figured it would be under water so it will be fine. πŸ˜•
                • soloS Offline
                  solo
                  Ooo, thanks, gonna try this.
                    Do you want my .blend file? It's a bit rough but you might see things that raise some questions?
                    • soloS Offline
                      solo
                      Yeah, always good to compare things and learn tricks, thanks
                      • boofredlayB Offline
                        boofredlay
                        Yes, glad you started this thread Pete.
                        I started learning Blender a few months ago and like everything I try to tackle I have to do it in small doses because of time issues.
                        Anyway, I have been following the Blender Tutor http://www.blendertutor.com/page/4/?fp_type=news with pretty good results.
                        I finished the coffee pot and am starting the SNES machine tutorial next.
                        I think I have a better image at home but I am not at home now so...
                          Here you go....
                          thea-logo-su.zip
                          Load file
                          Press 0 for Camera view
                          Press Alt+A to play animation
                            • soloS Offline
                              solo
                              @rich o brien said:
                              Here you go....
                              [attachment=0:7zja5vc2]<!-- ia0 -->thea-logo-su.zip<!-- ia0 -->[/attachment:7zja5vc2]
                              Load file
                              That is a clean logo. Hmm, basic mesh with a sub-D modifier only.
                              So this is modeled in SU, exported to Blender and added a modifier only?
                              I'd love to sit next to you as you model this in SU as I cannot seem to get my head around what tools you used and your workflow, then I need to still figure out the material assigning in Blender, I did a tutorial this weekend and it's already forgotten. πŸ˜•
                                Yes modeled in SU to a point just to figure out vert placement and form. Then into Blender for tweaking and some edge loops, creases and sub-d
                                  BTW, a better way to figure what key does what...
                                  http://waldobronchart.be/blenderkeyboard/
                                  • soloS Offline
                                    solo
                                    Now I'm goofing around with fluid flow.
                                    I'm learning Blender arse about face, doing fluids, then particles and fabric.
                                    I want to have fun learning.
                                    Some crazy DOF and HDRI lighting with a few emitters.
                                      Is that with Thea plugin?
                                      • soloS Offline
                                        solo
                                        Yes.
                                          I must invest in it.
                                          • soloS Offline
                                            solo
                                            Looks like it's free.
                                            http://www.thearender.com/cms/index.php/plugins/thea-for-blender.html
                                            Oh, do follow the installation guide as I messed up initially, there are a couple of steps that are important.
                                            • 8
                                            • 9
                                            • 3 / 9
