    Syd Mead's VEX (model progression)
    75 Posts 12 Posters 8.8k Views 12 Watching
    • Bryan KB Offline
      Thanks Box and Pilou, but I have to remake the tread. After experimenting with it last night, it's wrong.
      • Bryan KB Offline
        What. A. Pain! πŸ˜†
        I had to free float the arcs for the tread springs and that only took a few hours to get aligned, then used the "Follow Me" tool to draw square tube along the arc and that took a few more hours.
        So don't look to close because it still needs tweaking at the rim knuckle joints.
        But more or less, this is it.
        • iichiversiiI Offline
          iichiversii
          Great work on the wheel Bryan πŸ‘
          Bring on the Rain...
          • Bryan KB Offline
            Thank you iichiversii. I still feel kind of stupid because the result it not what I was looking for, but I only have two pictures to use as references.
            I will be refining the wheels until next week.
            Until I get tired of it. πŸ˜‰
            Just two more things... just two more... πŸ˜†
            • Bryan KB Offline
              x-ray
                Cool kit but, sod mars and other off world jaunts, this would be MUCH better for the weekly shopping trip to tesco/asda et al.
                • Bryan KB Offline
                  πŸ‘ πŸ˜†
                  • Bryan KB Offline
                    It's done. On to the main vehicle.
                    • Bryan KB Offline
                      Right now it's just a dog. And what do dogs say?
                      Rough, rough. πŸ˜†
                      I can see this one is going to take about a month as well.
                      • Bryan KB Offline
                        Update
                        • ely862meE Offline
                          ely862me
                          I am watchin' you ! πŸ€“
                          Elisei (sketchupper)
                          Come and See EliseiDesign
                          • tademaT Offline
                            tadema
                            Looking good Bryan πŸ‘
                            No pressure at all when the Crème de la crème of the car modeling world writes
                            "I am watchin' you !" πŸ˜†
                            John
                            • Rafferty94R Offline
                              Rafferty94
                              Looks really good Bryan! Looking forward to the updates..
                              • Bryan KB Offline
                                If no one has any major objections or comments, this is the overall shape I'm proceeding with.
                                In other words, this is the frame I will finish detailing.
                                (never post hung over πŸ˜‰ )
                                • Bryan KB Offline
                                  Thanks guys, then I will move ahead with this shape. πŸ‘
                                  • Bryan KB Offline
                                    Update
                                      iichiversii
                                      coming along nicely πŸ‘
                                      • ely862meE Offline
                                        ely862me
                                        Forgive me ,I have not watched carefully the pictures and the model, but i believe the side back panel is not broken like you did. I think it is one plane.
                                        Care to send the model by pm or here if ok and I will try to adjust a bit ?
                                        • Bryan KB Offline
                                          The problem is two-fold: Syd's drawings are forced perspectives as I found out doing a photo-match and neither exactly matches the other and the actual clarity of details leaves a lot to be desired. The best I could get from the photo-match was general dimensions.
                                          The second part is the sides are actually warped trapezoids, so the only way SU can complete the surface is to divide it into a polygon. I tried several different ways to manually create the polygons and this was the best compromise I could get as I had the same issue with the front side panels.
                                          It will have to do.
                                          • Bryan KB Offline
                                            Update.
                                            On Elisei's suggestions, I tried to tweak the rear side panel a little more. I like the new results, but still have the problem of it being a warped trapezoid. However, I do like the improvement. I also had the rear face too small, and enlarging it helped.
                                            Other details added.
                                            • 2 / 4
