    Depth of Field problem vray sketchup
    renderpluginsextensions
    19 Posts 4 Posters 6.7k Views 4 Watching
    • tes031T Offline
      tes031
      Hi, im newbie here.
      i have a problem about DOF in vray for sketchup (im using vray 2.0 beta)
      i tried using dof in my scene but it won't blurring
      so here my setting
      the distance between the camera and the object is 1.40 meters = 55.1181 inch
      so i type 55.11 into override focal dist box
      and the camera tab setting is default except dof's setting.
      when i render it, it won't blurring just like in this tutorial
      http://sketchupvrayresources.blogspot.com/2011/08/tutorial-depth-of-field-dof-in-vray.html
      heres the render
      http://sketchucation.com/forums/download/file.php?mode=view&id=111425&sid=2acbd86c48b0d0ee4fe87d29ca04f94b
        rspierenburg
        What are your Physical Camera settings?
        • V Offline
          valerostudio
          Make sure DOF is enabled in your camera settings and set your camera focus using the tool on the VR Toolbar (looks like a crosshair).
          • tes031T Offline
            tes031
            heres my physical camera setting..
            • tes031T Offline
              tes031
              set your camera you mean tools > advance camera tools > create camera
              i do follow the instruction on Nomeradona blog
              Tutorial: Depth of Field (DOF) in Vray SketchUp8
              Apiwat Hngimhyun  made this as part of his "The Making of Contemporary Kitchen" which we posted last week .  On the other hand, there is a ...
              (sketchupvrayresources.blogspot.com)
              • V Offline
                valerostudio
                Can you share the scene?
                • dkendigD Offline
                  dkendig
                  the new "set camera focus" button in our toolbar eliminates the need for this workflow.
                  Devin Kendig
                  Developer
                  • dkendigD Offline
                    dkendig
                    @tes031 said:
                    Hi, im newbie here.
                    The beta has been over for a while, are you using the public release version (2.00.23590)?
                    Devin Kendig
                    Developer
                    • tes031T Offline
                      tes031
                      here the skp file
                      lat1.skp
                      • tes031T Offline
                        tes031
                        im sorry where i can find set camera focus toolbar, i can't find one 😞
                        • tes031T Offline
                          tes031
                          @dkendig said:
                          @tes031 said:
                          Hi, im newbie here.
                          yes, i used that one
                          is something wrong ? like 2.00.2 won't running DOF correctly or i do some mistake with my DOF setting ?
                          • V Offline
                            valerostudio
                            Works for me. Maybe because you don't have the latest licensed version??? The only thing I did was add more lighting, colors, and reduced the F stop to 3 to exaggerate the Bokeh.
                            • dkendigD Offline
                              dkendig
                              http://content.screencast.com/users/arachnode/folders/Jing/media/88a2f6da-c8d2-4821-bc95-f0ca994ae824/VfStoolbar.png
                              It's the little cross hair icon, right above the Freeze RT View button.
                              Devin Kendig
                              Developer
                              • tes031T Offline
                                tes031
                                [attachment=0:3v43p4rb]<!-- ia0 -->DOF Test.jpg<!-- ia0 -->[/attachment:3v43p4rb]
                                oh i see, thank you very much 😄
                                • tes031T Offline
                                  tes031
                                  i can't find it on my vray toolbar, maybe its not for public version.
                                  but, thank you very much 😄
                                  • dkendigD Offline
                                    dkendig
                                    it's definitely in the public version. We now have 2 toolbars, so perhaps you're just not showing one of them? There should be "VfS Lights" and "VfS Main Toolbar" in the toolbar settings.
                                    Devin Kendig
                                    Developer
                                    • tes031T Offline
                                      tes031
                                      my vray toolbar start from material editor, the last one is import proxy icon
                                      theres 16 icon in my vray toolbar.
                                        rspierenburg
                                        I'm guessing the OP is using VFSu 1.6x
                                        • dkendigD Offline
                                          dkendig
                                          Window->Preferences->Extensions and click on V-Ray for SketchUp. What version does it say you're using? FYI- The version displayed in the VFB displays the core V-Ray version, not the version of V-Ray for SketchUp that you're using.
                                          Devin Kendig
                                          Developer
