    Sketchup Make (2013)
    7 Posts 5 Posters 1.1k Views 5 Watching
    • G Offline
      grbmds
      I am just getting back into trying to design furniture and other woodworking projects with Sketchup. I downloaded Sketchup Make which I believed to be the newest version of Sketchup. A couple of questions:
      Is it better for me to continue to use Sketchup 8 for Woodworking?
      If I use Make, can I take my screen setup and plugins from version 8 and copy them into Make (since Make seems to have it's own folder and is separate)?
      I guess I'm just asking whether it's better to just start fresh with Make rather than using Version 8 which I suppose will be outdated at some point?
      Sorry if this has already been addressed in other places.
        mics_54
        oh good question..
        I'm at that very same crossroads my self.
          It's always best to install plugins fresh as it ensures you've the latest versions and it means you install what you need and trim away what has cluttered your folder in the past.
          You should be aware that Make is for non commercial activities.
          But you can happily run v8 free and Make on the one system. Though upgrading means you lowered your chances of losing work through bug splats.
          • G Offline
            grbmds
            Thanks for the advice. My use is non-commercial. Does Make function like Version 8; at least in the basics? I don't want to have to learn all over again.
            • cottyC Offline
              cotty
              Yes, it is, you only have to "learn" the new icons...
              my SketchUp gallery
                FWIW, you could open your V8 starting template in SU2013 and save it using File>Save as template... At least you'll get the units, style and camera position that you're used to.
                You'll need to set up your toolbars where you want them. And you can make custom toolbars to include the native tools you use and skip those you don't use at all.
                • G Offline
                  grbmds
                  Thanks for the help. I figured it was likely to be easy as it usually is with Sketchup, but your verification is good for reassurance.
