    Slimming cure
    3 Posts 2 Posters 581 Views 2 Watching
    • M
      marcuus
      hi,
      I want to know if there is another way to lower the weight of my models, while maintaining a high number of polygons, and of course I use the plug-in, clean up, also erase duplicate face during hours, but sometimes it increases the weight, and sketchup when working over 20/25 mb you can not even move a component or group, or assembly, without difficulty;
      so I tried to copy and paste each finished component in a new file design and then assemble everything before cleaning, but it does not work. What to do? is there any solution? πŸ˜„
      thank you in advance
      • M
        mac1
        There are a number of suggestions here https://sites.google.com/site/sketchupsage/faster.
        Many yimes the large size is cause by use of photo textures which are too big.
        Try setting you rendering option to monochrome while you model and see if that helps and use textures for " show and tell " etc.
        In windows , model inf, stats do a purge to get rid of any unused " stuff"
        Post the problem model if ok to do so, the size you have is too large for an upload herein ( 10MB limit), so you will have to use a file sharing site like drop box or Google drive, load there and then post url location here.
        • M
          marcuus
          thank you sir,i dont use a texture photo in this model,but there are 63 component so I will try to use google drive and i just download now a ruby plugin purgeall .many thanks β˜€ CONIGLIETTO 3D CUCCIOLO immagine esporta.jpg
