    Circle and arc segment amount for 3D printing
    17 Posts 5 Posters 3.6k Views 5 Watching
    • J
      jaxcoffee
      Could anyone with some experience tell me what the minimum segment count can be for still having a smooth output for 3D printing?
      • cottyC
        cotty
        It depends not on the segment count but on the segment length. The printer resolution is different with different print technologies, so this must be considered too.
        edit: example with no visible segments
        my SketchUp gallery
        • J
          jaxcoffee
          Thanks Cotty, but I'm not sure what you mean by segment length? I can only set one number. Are we talking about the same thing, but just calling it something different? What was your circle segment set on for the example you show? Thanks
            The segment length would be dependent upon not only the number of segments but also the radius of the arc. A small radius might not require as many segments as a large radius. You can see that when you are drawing in SketchUp, too.
            • J
              jaxcoffee
              So what I'm getting from both comments is that there is no set or standard number for achieving a good smooth surface when outputted to a 3D printer. Is that based on your actual experience with 3D printing? I'm really trying to find a set number so I can just model within my projects, and not have to reset arc and circle segments for every little change in size.
              Has anyone experienced any kind of trial and error with outputting to 3D printing to find a happy medium for detail, but not have any post printing extra work to do to make a circle look smooth?
              Thanks for your input guys.
              • cottyC
                cotty
                Yes, have a look at this shapes with an 12 segment arc: one maybe printed smooth but the other not because of the different segment length...
                And there are many different materials you can use with 3d printing, every one with a different smallest geometry, ... so this influences the needed segment length too.
                my SketchUp gallery
                • J
                  jaxcoffee
                  I understand what you are saying Cotty by segment length, but that length is determined by the number of segments in a given arch/circle. Which is how it is setup in SketchUp.
                  So it appears I may need to ask the question of those who would be doing the output. Also it seems that if one is modeling a project, one could determine by the largest circle/arch what is the smoothest output for it, and just let it be what is used by the smaller circles also.
                  So can I assume that having too many segments in a smaller circle would not be a negative issue with 3D printing?
                  • cottyC
                    cotty
                    I would agree.
                    my SketchUp gallery
                    • J
                      jaxcoffee
                      This is quite interesting and right along the same lines as we are talking about.
                      I just had the president of a 3D output company called Build Parts tell me that 99.9% of the files they get from objects modeled with SketchUp don't work.
                      Can someone elaborate on why that may be true? I don't want to have to learn Solidworks, which seems to be the standard for 3D print output companies.
                      Has anyone really looked into what needs to be improved within SketchUp to bring things up to speed for this technology?
                      • cottyC
                        cotty
                        Most of the modellers don't care about solid object, maybe he is referring to "bad" modeled warehouse models?
                        For me 100% percent of my printed parts were printable on the first try.
                        my SketchUp gallery
                        • J
                          jaxcoffee
                          I thought that items did not have to be solid objects? Am I misunderstanding your comment? Modeling in solids means the purchase of the pro version if I understand that correctly. I'm really just trying to learn how to model the best for 3D output, so getting these answers are important to developing a workflow for our project.
                          And of course if we have to be making a purchase of the Pro version of SketchUp, I would like to know before getting to deep into our work. Thanks
                          • cottyC
                            cotty
                            You don't need the PRO version to make solid objects!
                            A simple rule for solid objects (groups or components): every edge touchs exactly 2 faces (no groups/components inside)
                            my SketchUp gallery
                            • cottyC
                              cotty
                              Here are some more hints by Aidan Chorpa: http://www.dummies.com/how-to/content/understanding-solid-objects-in-google-sketchup-8.html
                              (Hint: making solid objects deson't need solid tools, which are 'editors' in the PRO version)
                              my SketchUp gallery
                              • D
                                d12dozr
                                Carsten is quite right - most modelers don't care, or more importantly don't know how to make solid objects.
                                Your reaction is a perfect example - you are a good modeler and as long as you have been using Sketchup to make models, you didn't know what solid models are. I think this is a result of poor marketing and inadequate education from the Sketchup team.
                                Part of the problem also lies with Sketchup itself, where punching a circle in a face can turn a seemingly perfect model into a mess of intersecting faces and 'bad edges'.
                                http://goo.gl/f7ooYh
                                • M
                                  mac1
                                  FYI; some interesting info https://www.google.com/search?sourceid=navclient&ie=UTF-8&rlz=1T4NDKB_enUS554US555&q=jay+leno+3d+printing
                                  • M
                                    mac1
                                    And this http://www.stratasys.com/~/media/Main/Secure/White%20Papers/Rebranded/SSYS-WP-AccuracyMyth-03-13.ashx
                                    copy and paste link
                                    • D
                                      d12dozr
                                      Mac, I couldn't get your link to work, but changing the filetype to PDF worked...like this (PDF download): http://www.stratasys.com/~/media/Main/Secure/White%20Papers/Rebranded/SSYS-WP-AccuracyMyth-03-13.pdf
