    Window material
    renderpluginsextensions
    6 Posts 2 Posters 597 Views 2 Watching
    • izabelavictoriaI
      izabelavictoria
      Hello,
      I need some help with a good material for windows. I'm doing an interior visualisation and I would like to create material that allows me to see everything that's behind the window but also makes some reflactions of my interior. Whenever I add a refraction, I loose the view of the outside and I don't really know how to create a good effect. I uploaded my interior visualisation.
      Thanks for any advises πŸ˜„
      • V
        valerostudio
        If your glass is a single plane, you want to give it some thickness, like .12 and use a standard glass material. I have attached one, but if you are not using v2.0 it might not load correctly.
        glass_basic.vismat
        • V
          valerostudio
          Nomer has nice resources on his site as well.
          http://sketchupvrayresources.blogspot.com/2011/07/vray-sketchup-glass-material.html
          • V
            valerostudio
            You can also use a single plane for the glass with a thin glass material. I've attached one that I use sometimes.
            ThinGlass.zip
            • izabelavictoriaI
              izabelavictoria
              Thank you all very much πŸ˜„
              • V
                valerostudio
                One more material here that I use sometimes. This uses a lot of artistic license, but sometimes you just want a glass material to appear 'glassy'. This is a cheat that does not use Fresnel and is not fully transparent. It's a nice cheater.
                ThinCheatGlass.zip
