Import multiple dwg files into SU in one shot?
I recently bought profile builder and would like to mass import a bunch of my molding profiles into SU in one shot to convert to a molding library for Profile builder. My Profiles are in dwg. Is there some plugin or other method for me to import more than one dwg at a time?
Can you not combine them in whatever program you created them in into one "page" of profiles and import that.
Made in AutoCad. I have the same problem there. Individual block imports to create the file. I might as well do it in SU and cut out 1 step.
Oh well, in other programs, Coreldraw for example, It is possible to drag and drop multiple files into a new file then save the file as one set of profiles.
Look in the SCF PluginStore for my batch importer, which will import all files of a given 'type' found in a folder...
Register LoginAdvertisement
