    Final image size
    renderpluginsextensions
    4 Posts 3 Posters 512 Views 3 Watching
    • U Offline
      UpNorthMN
      New to V-Ray for SketchUp. Using v-Ray 2.0 and SU 2013. I searched the forum first, but cannot figure out how to get a decent size/resultion image. I have cranked up the pixel values iunder "output" but that does not have any affect. I see mention of the term "final render" in the forums but not sure if that is a button or a concept:)
      Thanks.
      • V Offline
        valerostudio
        If you are using the demo, I believe it has a size limitation.
        • U Offline
          UpNorthMN
          Thank you... I thought I read the demo had no limitations. I just went back and looked and see the maximum size is 600x400.
          • dkendigD Offline
            dkendig
            prior versions had different or less... or no limitations. It's changed a few times, so it's hard to keep straight in my head. Currently though, yes, there is a watermark, output size cap, and a few other limitations here and there.
            Devin Kendig
            Developer
