    Saving a row of variables into a text-file
    3 Posts 2 Posters 244 Views 2 Watching
    • artmusicstudioA Offline
      artmusicstudio
      hi,
      with this code i can save a row of my variables to a text - file, but in one line
      file = File.open("C:/Program Files (x86)/Google/Google SketchUp 8/Plugins/zf/partemp.txt", "w") { |f|
      f << lines[0].to_f
      f << lines[1].to_f
      f << lines[2].to_f
      when i try to separate the values by \n, there is a syntax error:
      f << lines[0].to_f\n
      f << lines[1].to_f\n
      f << lines[2].to_f\n
      no tips about this on the net.
      any tips for the syntax?
      thanx stan
        You don't clarify what lines[0] is??
        f.puts(lines[0].to_f.to_s)
        this adds a line of text, and puts automatically adds the "\n" at the end
        Why make it into a float unless you are trying to format it in some way ?
        The file itself will hold only a string?
        Another way... if the lines in the array are already in strings is:
        string=lines.join("\n")
        then 'sting' is something like:
        "1.2\n3.4\n5.6"
        so then just do one puts into the file with:
        f.puts(string) ?
        You need to do some more reading up on reading/writing files... and numbers versus strings etc...
          artmusicstudio
          hi tig,
          ok, you are right, puts does it automatically.
          the declaration of the variables happens in the beginning of the ruby,
          first loaded from the default file and then possibly changed by the user...
          these settings then create the geometry and are saved to a separate file (later as function : reload last user parameters).
          will just try the puts-version.
          stan
          EDIT: IT WORKS
          parameters are saved at the end of ruby
          and
          automatically reloaded on start
          πŸ˜„
          wonderful!
