    Some Navigation Suggestions
    5 Posts 3 Posters 365 Views 3 Watching
      BustedClock
      A couple of things that I think would improve SketchUp navigation:
      1. A way to one-click (context menu?) change camera to the opposite end of the component. Not like flip along axis because I want the whole model to flip even though I'm working on a single component. Also, not the camera-view menu/buttons, because I don't necessarily remember which side of the model I'm working on. Heat of the moment, and all that.
      For example: I'm working on a slat, say for a bed, creating a mortise. I want a right-click that flips ME to the other end of the component. So, if I was looking at the right side of the model, focused on one component, I'm now looking at the left side of the model, but focused on the opposite end of the same component.
      1. Another context-menu button that immediately places what I'm working on in the middle of the screen. It's sort of uncomfortable for me to work on something in the lower-left corner of the screen (character defect, I guess). I want, with one click -- and without changing orientation or zoom level -- to move the component (and the model surrounding it) to the middle of the screen.
      For example: Same as above, but the slat is the fifth of five. Rather than click on the pan button, or use the center-button + left-button mouse gesture (on Win), I just want to right click on the place where I'm working, then click "center" on the menu. One thing about the mouse type actions is that it doesn't always work (or I'm clumsy), and ends up orbiting rather than panning. I can't freaking stand that!
      Cheers!
      BustedClock
      • cottyC Offline
        cotty
        Sounds like "Zoom Extents" from the context menu?
        my SketchUp gallery
          BustedClock
          Actually, I've only tried zoom extents a couple of times, but it seemed to distort what I was looking at. I guess, or I think (not sure which!), that it zoomed the whole component to fill the screen. I simply want to move the area I'm working on to the center of the screen.
          I'll have to try it again. Maybe I didn't see what I thought I did!
          Thanks!
          • cottyC Offline
            cotty
            Thanks!
            Why not use the middle mouse scroll wheel button together with the left mouse button?
            my SketchUp gallery
              That's what Zoom Extents is supposed to do. The one from the Context menu zooms in on the selection so if you have a face or an edge selected when you choose it, the view will zoom in to it.
              As to the distortion yousee or think you see, perhaps you would find it easier if you reduce the camera's field of view. Select the Zoom tool from the toolbar or Camera menu and type a new value in the VCB. If you wish, you can use focal length instead of degrees by typing mm after the number.
              You don't really want to flip the model do you? It sounds more like you want to Orbit the camera 180° from its current location. Would that be correct? Well, 180° might not be the right amount. Maybe it is 90° or 110° along the length of the component. How do you determine what the angle should be?
              It sounds to me like with practice in using the existing navigation tools, you'll find you can do quite well with them. Use the center mouse button/wheel and combine it with Shift for Pan and I think you'll find you get along just fine.
