    Error message for plugins when Sketchup 8 (free) is opened
    8 Posts 2 Posters 2.0k Views 2 Watching
      amitg43
      Recently installed TT_ArchitectTools and TT-Lib2 through the preferences>extensions route. When I open Sketchup 8, I get the following error message:
      Error Loading File C:/Program Files (x86)/Google/Google SketchUp 8/Plugins/TT_Lib2/bezier.rb
      no such file to load -- C:/Program Files (x86)/Google/Google SketchUp 8/Plugins/TT_Lib2/libraries/win32/TT_Geom_BezierError Loading File C:/Program Files (x86)/Google/Google SketchUp 8/Plugins/TT_Lib2/gl_image.rb
      no such file to load -- C:/Program Files (x86)/Google/Google SketchUp 8/Plugins/TT_Lib2/libraries/win32/TT_Geom_BezierError Loading File C:/Program Files (x86)/Google/Google SketchUp 8/Plugins/TT_Lib2/bezier.rb
      no such file to load -- C:/Program Files (x86)/Google/Google SketchUp 8/Plugins/TT_Lib2/libraries/win32/TT_Geom_BezierError Loading File C:/Program Files (x86)/Google/Google SketchUp 8/Plugins/TT_UV_Toolkit/loader.rb
      no such file to load -- C:/Program Files (x86)/Google/Google SketchUp 8/Plugins/TT_Lib2/libraries/win32/TT_Geom_BezierError Loading File tt_uv_toolkit_2.rb
      My comments:
      C:/Program Files (x86)/Google/Google SketchUp 8/Plugins/TT_Lib2/bezier.rb - this is a valid path for bezier.rb file which is available
      C:/Program Files (x86)/Google/Google SketchUp 8/Plugins/TT_Lib2/gl_image.rb - this is a valid path for gl_image.rb file which is available
      C:/Program Files (x86)/Google/Google SketchUp 8/Plugins/TT_UV_Toolkit/loader.rb - this is a valid path for loader.rb file which is available
      C:/Program Files (x86)/Google/Google SketchUp 8/Plugins/tt_uv_toolkit_2.rb - this is a valid path for tt_uv_toolkit_2.rb file which is available
      C:/Program Files (x86)/Google/Google SketchUp8/Plugins/TT_Lib2/libraries/win32/TT_Geom_Bezier - TT_Geom_Bezier is not available in that path
      The drop-down list from Draw menu lists Bezier Curves. The Plugins menu drop down list shows Architect Tools.
      My system is Windows 8 Pro (64 bit) and I use Sketchup 8 free version.
      How do I eliminate the message?
        You haven't entered details like OS in your user profile - I'm guessing it's a PC and v8 or newer...
        The extensions installer can be fooled, if you have some restricted security permissions to the Plugins folder...
        It might look like they are installed but some files/subfolders end up in a VirtualStore.
        Windows protects you from yourself by limiting rights to access all folders within the Program Files folder-tree, by default...
        To be able to add and manage plugins you need FULL permission.
        To fix this you need to be an admin [if you are not one give yourself the power from the Users Control Panel]
        Firstly close SketchUp.
        Next... if you have given your Plugins folder a custom icon then remove it - doing this can slightly affect the folders permissions and although they report as 'FULL' they can be sufficiently restricted to affect installations...
        Next...
        Find the main Plugins folder and select its icon
        Right-click > Context-menu
        Properties
        Security
        Edit...
        Set every user/group in the list to have FULL read/right permissions.
        Apply/OK
        Next...
        Find the SketchUp.exe file in the same folder that contains the Plugins folder and select its icon
        Properties
        Compatibility
        Tick the box near the bottom, 'Always Run As Administrator'
        Apply/OK
        Now restart SketchUp and try reinstalling the tools...
          amitg43
          Next...
          Properties
          Security
          Edit...
          Apply/OK
          Next...
          Properties
          Compatibility
          Apply/OK
          Thanks for your detailed instructions.
          My laptop is DELL Inspiron N5110, recently upgraded from Windows 7x64 to Windows 8 Pro x64.
          After following your instructions, I reinstalled TT_Lib_v2.8.3.rbz and restarted Sketchup. First a blank window appears with title TT_Lib2 not installed, then replaced by a window titled Load Errors displaying the same error messages mentioned in my earlier mail.
          A TT_Lib2 folder is very much there inside the Plugins folder (C:\Program Files (x86)\Google\Google SketchUp 8\Plugins), hence I do not know why it cannot be found by the application.
          Anything else to try?
            So it looks like you have fixed the Plugins folder security permissions issue BUT...
            You must reinstall ALL required files/folders now that you have fixed the permissions.
            Please try reinstalling the latest LibFredo now...
            If might look like the Lib is installed in the Plugins folder, BUT Windows has probably put it into a VirtualStore - it protects you from yourself by stopping you installing things if you havelimited rights, but it doesn't tell you !
            The only clue is if there is a button link in the top bars of your Windows Explorer window for the Plugins folder, saying something like 'Compatibility Files...', then that is a sure sign of a VirtualStore issue. You can click to open that and see what has not been installed properly...
            Reinstall them from scratch...
              amitg43
              In the Windows Explorer window for the Plugins folder, no button like 'Compatibility Files...' appears.
              In any case, I have reinstalled LibFredo6_v5.2a.rbz but the status of my problem remains same.
              A new thought. I mentioned that I recently went from Windows 7x64 to Windows 8 Pro x64, but my Sketch up 8 free is continuing from Windows 7. Can it cause a problem? Should I go for Sketchup Make which is the current free version of Sketchup? But if I do that, will I need a complete reinstallation of all the plugins?
                To find your correct Plugins folder for any SketchUp version... open that version of SketchUp and open the Ruby Console, then type in:
                Sketchup.find_support_file('Plugins')
                which gives you the full path to the Plugins folder...
                Check for FULL permissions to that Plugins folder and if the expected plugin files and subfolders are indeed inside it πŸ˜•
                Each SketchUp version installation should be completely separate.
                Each will have its own Plugins folder etc.
                This sounds like a real mess... πŸ˜’
                If you do not use v7 then can I suggest that you uninstall it, and then uninstall v8 and reinstall v8 properly, or get a new install of v2013 - get new versions of your various plugins - many were rewritten to suit v1013...
                Any existing Plugins folder and its contents [or other customized folders] should be unaffected by the system 'uninstall'.
                  amitg43
                  Thanks for explaining what you rightly described as 'a real mess'!
                  Today I uninstalled TT_Lib2 folder, TT_ArchitectTools, and other TT plugins but not the associated .rb files. I opened Sketchup and this time the window titled "TT_Lib2 not installed", which earlier used to be blank, now displayed that I should install the latest version "TT_Lib2-2.8.0.rbz" (earlier I had TT_Lib_v2.8.3.rbz) with a download link. I then deleted the .rb files also from the Plugins folder and installed the new Lib2, then all other deleted plugins. Now Sketchup opens fine and there are no error messages.
                  Thanks again for your patience and help to resolve the problem.
                    When a tool throws an error and it tells you it needs Lib-1.2.3, it sets that as the minimum requirement, so Lib-1.1.1 will not do, BUT the the only available version is newer, like Lib-1.2.8, then it should still work πŸ˜„
                    It'd be better if it were to say it needs 'Lib-1.2.3 or higher'...
                    So don't worry too much about that side of thing...
