    Displacement issues
    renderpluginsextensions
    4 Posts 3 Posters 493 Views 3 Watching
      tparks
      I tend to have this issue pretty frequently, and it is quite bothersome when using some textures.
      Basically I have a ceiling grid texture and displacement map that I made. The displacement map is just the grid, no aliasing on the lines or anything.
      However, when I render it. I get weird wavy or squiggly artifacts. This happens to me with a lot of my brick & tile textures, too.
      What setting do I need to adjust?
      See image for example.
        rspierenburg
        You can try to Set the Filter value in the displacement map to 0 to see if that helps.
          tparks
          I think I fixed it... I turned the subdivs down to 1. Weird.
          • V Offline
            valerostudio
            2.0 bump mapping has improved significantly. I would not use displacement on tiles or bricks. Seems like an incredible waste of render time to me. Try bump, trust me.
