    ๐Ÿ”Œ Smart Spline | Fluid way to handle splines for furniture design and complex structures. Download
    [Plugin] SketchUcation Tools
    388 Posts 86 Posters 158.4k Views 84 Watching
      Report back later. Caching sh!t
        It's not a cache issue my side...
        It's empty. ๐Ÿ˜•
        Here's what I still see in IE8 screengrabbed...
        The td's for the desc & buttoncontainer need to vertical-align:top; ?
        Remember I can't see the current html - you have recently stopped right-clicking view-source in the dialog! ๐Ÿ˜’
        So I'm working off an older copy ! ๐Ÿ˜•
        • G Offline
          Gรกbor
          It's empty. ๐Ÿ˜•
          Please try it now with cache refreshed.
            Now it's messed up on IE10 !
            The desc goes under the img !!
            I can't see the html to see what's changed.
            If I use an old version of the html and change the td style for the desc & buttoncontainer to have style="vertical-align=top;" it looks OK in IE10 AND IE8 too...
            You need to set that style to the two td containers and it should be OK ?
              @tig said:
              IRemember I can't see the current html - you have recently stopped right-clicking view-source in the dialog!
              You can check the serving .php anytime you want
                I know, but it's a faff...
                Anyway I have a solution in vertical-align:top; for the two td's holding the desc and the buttons... either as a new/modified class class or in the html <td style=... itself... ๐Ÿ˜•
                  Whatever you did to it, now it works OK for me in both IE10 AND IE8 mode...
                  Real IE8 feedback from Fredo et al should clinch the fix...
                  • OxerO Offline
                    Oxer
                    Hi, I installed the last version and it appears this error window when I run SU 2013 on Mac OSX 10.8.5
                    http://www.oxervision.blogspot.com/
                      @Oxer
                      Did you restart SketchUp after the update [as instructed] ?
                      DO you have FULL read/write permissions to your main Plugins folder ?
                      If it still gives errors...
                      Close SketchUp.
                      Then remove all of the installed files.
                      That is - the !SketchUcation_loader.rb file and the ../Plugins subfolder of files etc named SketchUcation.
                      Now reinstall the file either from the latest RBZ downloaded from the SCF PluginStore, using Preferences > Extensions > Install... button, OR use the SketchUcation Plugin Store dialog in SketchUp itself to AutoInstall it...
                      Restart SketchUp and report back ๐Ÿ˜•
                      • OxerO Offline
                        Oxer
                        Hi TIG,
                        I reinstalled the plugin and Ok now, the problem was the SCF-ES.strings file, I had not modified the file with the new strings.
                        But in the new SCF-EN-US.strings file aren't included these:
                        "Plugin data is not available"
                        "Highlight an Item to See Its Details..."
                        This is the new SCF-ES.strings v2.0 file
                        Spanish Language-SketchUcation Tools 2.0
                        • cottyC Offline
                          cotty
                          Win7-64 with IE9: fine!
                          my SketchUp gallery
                            @oxer said:
                            Hi TIG,
                            [attachment=0:1uttvlrg]<!-- ia0 -->SCF-ES.strings.zip<!-- ia0 -->[/attachment:1uttvlrg]
                            So, if you have a custom .strings file, you need to review it and update it if there are extra functions added... like in this case... ๐Ÿ˜’
                            The two phrases you mention are NOT translated because they are related to the SCF database entries responses, which are all in EN only ๐Ÿ˜•
                            • OxerO Offline
                              Oxer
                              Thanks for the reply TIG!!
                              • JQLJ Offline
                                JQL
                                Hi all,
                                What an excelent plugin this is! Getting better and better each release. I got a feature sugestion that you might consider:
                                • What about having a button for release notes for the plugins? I know we can click on more info but, for plugins we already are familiar with, only the release note/changelog would be necessary.
                                Thanks for your excelent work and best regards,
                                JQL
                                www.casca.pt
                                Visit us on facebook!
                                  @JQL
                                  We are going to go one better soon ๐Ÿ˜‰
                                  A Eureka moment happened today....
                                  • JQLJ Offline
                                    JQL
                                    You were fast or what Rich? I suppose there are no original ideas... ๐Ÿ˜’
                                    www.casca.pt
                                      Any idea is good. You just added to the to-do pile ๐Ÿ˜‰
                                        johnwmcc
                                        I've installed SketchUcation Tools 2.0, apparently successfully, in SU Make 2013.
                                        I try to use Plugins Manager, and immediately get the error message
                                        SketchUp
                                        NO Security Permission to Manage ANY Plugins Folder in the $LOAD_PATH.
                                        FULL Read/Write Permissions are needed to Manage Plugins within Plugins Folders...
                                        OK
                                        I tried to fix this by changing Advanced Sharing settings in the Plugins folder, setting permissions for Everyone to All, and restarting SU.
                                        Also tried system restart after setting these sharing permissions.
                                        Still get the same message.
                                        Any further suggestions?
                                        I'm running Windows 7 Pro 64 bit, fully patched up to date, and the latest version of SU Make 2013.
                                        John McC
                                          right click the sketchup icon and run as admin
                                            johnwmcc
                                            It works if I start Sketchup with Run as Administrator. And I hope it solves the problem that AutoInstall of another program from the Plugins Store didn't seem to work earlier, though it gave no error messages.
                                            BUT...
                                            I log on to the machine as an administrator already, and the Quick Launch bar icon for SU from which I usually launch it doesn't have the option to Run as Administrator.
                                            So I have for the moment set the SU program properties to Run as Administrator by default, but I don't like doing that for programs supposedly written for Windows 7 or later.
                                            There's no problem using Window/Preferences/Extensions/Install Extension when NOT running SU as Administrator, which needs rights to write to the Plugins folder, so why does the Tools 2.0 Plugin not get itself the same rights by default? Surely this Tools plugin shouldn't trip up over permissions like this? I don't expect that from programs written in the Windows 7 or later era.
                                            Alternatively, would it not be better for SU to install its plugins in a folder that doesn't need special rights? In AppData for example, like other programs? I know you can have a script to load Plugins from other folders (and I have used that in the past), but would the Tools Plugin know about that?
                                            John McC
                                            • 19
                                            • 20
                                            • 3 / 20
