    [Plugin] SketchUcation Tools
    388 Posts 86 Posters 246.2k Views 84 Watching
      Now I see it !
      Consider this addition to the css
      img.smallimage {
        vertical-align; top;
      ๐Ÿ˜•
        fixed
          Does that now work in IE8 testing ?
          Not for me...
          In IE8 I'm still seeing the 'jumped-up' img, or rather the three cells of text to its right seems to be aligned to the bottom of its td cell and NOT its top ?
          Perhaps css
          td { padding: 0 4px; **vertical-align: top;** }
          too ?If that breaks other td's then add it to the html for that td as
          <td style="vertical-align: top;">
          OR make a new td class 'descriptioncontainer' ?
            Report back later. Caching sh!t
              It's not a cache issue my side...
              It's empty. ๐Ÿ˜•
              Here's what I still see in IE8 screengrabbed...
              The td's for the desc & buttoncontainer need to vertical-align:top; ?
              Remember I can't see the current html - you have recently stopped right-clicking view-source in the dialog! ๐Ÿ˜’
              So I'm working off an older copy ! ๐Ÿ˜•
              • G
                Gรกbor
                It's empty. ๐Ÿ˜•
                Please try it now with cache refreshed.
                  Now it's messed up on IE10 !
                  The desc goes under the img !!
                  I can't see the html to see what's changed.
                  If I use an old version of the html and change the td style for the desc & buttoncontainer to have style="vertical-align=top;" it looks OK in IE10 AND IE8 too...
                  You need to set that style to the two td containers and it should be OK ?
                    @tig said:
                    IRemember I can't see the current html - you have recently stopped right-clicking view-source in the dialog!
                    You can check the serving .php anytime you want
                      I know, but it's a faff...
                      Anyway I have a solution in vertical-align:top; for the two td's holding the desc and the buttons... either as a new/modified class class or in the html <td style=... itself... ๐Ÿ˜•
                        Whatever you did to it, now it works OK for me in both IE10 AND IE8 mode...
                        Real IE8 feedback from Fredo et al should clinch the fix...
                        • OxerO
                          Oxer
                          Hi, I installed the last version and it appears this error window when I run SU 2013 on Mac OSX 10.8.5
                            @Oxer
                            Did you restart SketchUp after the update [as instructed] ?
                            DO you have FULL read/write permissions to your main Plugins folder ?
                            If it still gives errors...
                            Close SketchUp.
                            Then remove all of the installed files.
                            That is - the !SketchUcation_loader.rb file and the ../Plugins subfolder of files etc named SketchUcation.
                            Now reinstall the file either from the latest RBZ downloaded from the SCF PluginStore, using Preferences > Extensions > Install... button, OR use the SketchUcation Plugin Store dialog in SketchUp itself to AutoInstall it...
                            Restart SketchUp and report back ๐Ÿ˜•
                            • OxerO
                              Oxer
                              Hi TIG,
                              I reinstalled the plugin and Ok now, the problem was the SCF-ES.strings file, I had not modified the file with the new strings.
                              But in the new SCF-EN-US.strings file aren't included these:
                              "Plugin data is not available"
                              "Highlight an Item to See Its Details..."
                              This is the new SCF-ES.strings v2.0 file
                              Spanish Language-SketchUcation Tools 2.0
                              • cottyC
                                cotty
                                Win7-64 with IE9: fine!
                                my SketchUp gallery
                                  @oxer said:
                                  Hi TIG,
                                  [attachment=0:1uttvlrg]<!-- ia0 -->SCF-ES.strings.zip<!-- ia0 -->[/attachment:1uttvlrg]
                                  So, if you have a custom .strings file, you need to review it and update it if there are extra functions added... like in this case... ๐Ÿ˜’
                                  The two phrases you mention are NOT translated because they are related to the SCF database entries responses, which are all in EN only ๐Ÿ˜•
                                  • OxerO
                                    Oxer
                                    Thanks for the reply TIG!!
                                    • JQLJ
                                      JQL
                                      Hi all,
                                      What an excelent plugin this is! Getting better and better each release. I got a feature sugestion that you might consider:
                                      • What about having a button for release notes for the plugins? I know we can click on more info but, for plugins we already are familiar with, only the release note/changelog would be necessary.
                                      Thanks for your excelent work and best regards,
                                      JQL
                                      www.casca.pt
                                      Visit us on facebook!
                                        @JQL
                                        We are going to go one better soon ๐Ÿ˜‰
                                        A Eureka moment happened today....
                                        • JQLJ
                                          JQL
                                          You were fast or what Rich? I suppose there are no original ideas... ๐Ÿ˜’
                                          www.casca.pt
                                            Any idea is good. You just added to the to-do pile ๐Ÿ˜‰
                                            • 19
                                            • 20
                                            • 3 / 20
