    MIDDLE-LINE - HOW TO CREATE?
    7 Posts 4 Posters 563 Views 4 Watching
    • artmusicstudioA Offline
      artmusicstudio
      hi everybody,
      i just came across the problem to draw a middleline of a road automatically.
      has anybody an idea, if there is a ruby, which can calculate the middle point in the geometry step by step and draw a line between these centerpoint?
      the red line shall be the result.
      thanx a lot
      stan
        dedmin
        What about Fredo's ToolsOnSurface - Offcet on Surface?
          artmusicstudio
          hi, thanx, yes, i already tried,
          but at the moment a get doubled lines in the middle , when the offset = 1/2 of the width.
          so creating a curve from the middle - line by WELD does not work yet.
          still trying.
          regards stan
          • fredo6F Offline
            fredo6
            Alternatively, you could use Curviloft (loft by spline), with
            • the 2 side contours
            • asking for 2 segments (2s)
            • in geometry parameters, as only for grid
            Fredo
            • yorik1984Y Offline
              yorik1984
              Use line, not surface
              http://storage2.static.itmages.ru/i/13/0929/h_1380473431_5965694_2c8280c076.png
                artmusicstudio
                to fredo:
                hi, i get to this point, but quitting / ok / whatever let the lines disappear again. how can i extract the middle line?
                thanx stan
                  artmusicstudio
                  to fredo:
                  thanx stan
                  to yorik1984:
                  thanx, yews, with one line it works. great.
                  thanx stan
