    [Plugin] s4u_Select
    10 Posts 6 Posters 14.3k Views 6 Watching
    • hdpvH Offline
      hdpv
      S4u Select v2.1.0
      http://sketchucation.com/resources/pluginstore?pln=s4u_selectool_v1.1.1
      http://extensions.sketchup.com/en/content/s4u_selectool
      Tutorial video:
      https://www.youtube.com/watch?v=eN0CH0SxCI0%26amp;list=PLfw9P5m29pNR11nzD9mfDyJRodmzVxKoy
      -Select Edges ,Faces follow Axis
      -Add tolerance
      s4u_selectool_v2.0.0
      -Select step face
      -Display unit
      -Save input user
      -Optimize code
      s4u_selectool_v1.1.2
      A suite of tools that allow you to make selection based on a wide variety of options. Select edges by lenght, select faces by area
      s4u_selectool_v1.1.0
      Select vertical edges,horizontal edges,length edges or slope edges.
      Select vertical faces,horizontal faces,slope faces or area faces.
      Select same length,select same area or select face parallel.
      s4u_selectool_v1.0.3
      Update: select face by number vertex
      s4u_selectool_v1.0.2
      Select vertical edges , horizontal edges or slope edges ,vertical faces , horizontal faces or slope faces
      Suforyou
      http://www.sketchupforyou.com
        Added to PluginStore
        • F Offline
          faust07
          Thank you so much! Very helpful. πŸ‘
            marcelopaoli
            Uau! Thanks for the Three great plugins! Made life a lot easier!! You're a Genius!
            • hdpvH Offline
              hdpv
              Reverse Faces with s4u_SelecTool
              http://youtu.be/zLhY383zOZ8
              Suforyou
              • E Offline
                Esense3d
                German Language File
                Thank You
                • E Offline
                  Einstein
                  Thank you for a great selection tool!
                  I got a small suggestion on how to make it even greater. You could add option for adding new selection based on parameters to current selection.
                  For example: currently if you want both vertical and horizontal edges selected you have to use s4u Select in combination with another plugin: selection manager because you cannot expand existing selection. Using s4u Select will always cancel current selection, unless I'm missing something. The most advanced and freedom-giving technique would be the one used by ArchiCAD - there's entire window where you can pick selection parameters and use logical operators: "and", "or", exclusions etc. But a single button like "add to current selection" would be just cool!
                  • hdpvH Offline
                    hdpv
                    Thanks,I will add it on some functions.
                    Suforyou
                    • E Offline
                      Einstein
                      Could you please add "select parallel edges" feature? It would be useful sooo often.
                      What was changed in the last - 4.1.1 version? I noticed no changes from 4.1.0.
                      Maybe it's just compatibility release.
                      May I kindly ask you to update the changelog? It's easier for a user to keep track of changes when new versions are described.
                      Thank you πŸ˜„
                      • E Offline
                        Einstein
                        Why is the plugin nagging me to update from 4.1.1 to 4.1.2, when I'm happy with my current version?
                        Has anything changed?
                        Are you going to make it a payware?
