    Plugins
    2 Posts 2 Posters 235 Views 2 Watching
      rstimler
      Just changed computers, and am now lost. Had installed a bezier curve extension, but cannot find it again. Downloaded the sketchup plugin store rbz file and don't understand the use of it. Need a little guidance here. Thanks
        If you have the latest SketchUp [version 8 or 2013], then under the menu item, Window > Preferences > Extensions you will have an 'Install from archive' button.
        That will install the contents of the selected RBZ file for you.
        Alternatively use that button to install the 'SketchUcation Plugin Store' Toolset [there are links in the Resources menu]... after that, then that tool will work within SketchUp itself, and it can download and auto-install plugins for you... as well as do many other useful things like managing plugins and extensions...
