    Bring back "Load saved toolbar"
    14 Posts 5 Posters 2.8k Views 5 Watching
    • ken28875K Offline
      ken28875
      Hi there,
      I have been quite annoyed by the new system that is supposed to fix the floating icons when SketchUp window is minimized.
      Before they had something like "Save Toolbar" and "Load saved toolbar" (can't remember the exact names) that will allow you to have your toolbar back the way you wanted after all the icons got messed up when minimizing the SketchUp window. It is not perfect but, you can fix it with one click of the mouse by reloading the saved toolbar.
      Now with the new system if you have lots of icons and you move some of them by mistake, the column or row of icons disappear and there is no way to fix that quickly but only by putting them back manually, assuming you remember what icons were there.
      Does anyone have that same issue?
      I wish Trimble could combine both, the new system and the save and load toolbar.
      Have a good day!
      _KN
      Follow Your Dreams.
      • GarethG Offline
        Gareth
        Hi Ken,
        I downloaded SU 2013 a couple of hours ago.
        I have just found the whole toolbar episode an absolute nightmare....I had intended launching into a new project, and here I am a few hours later trying to assemble my toolbars the way I have always been accustomed to, and without any success.
        Time is too precious and expensive to be consumed with things that should be trivial and work properly.....maybe I should bill Trimble for the time I am wasting.
        OK, so I am now searching the Forum for a simple, uncomplicated solution to the problem......and wasting more time....!!
        My job is to design, not stuff around trying to make a piece of software work...!!
        I apologise in advance if there is a solution staring me straight in the face that I have missed....but if that is the case, it is because it is borne out of shear frustration...!
        • cottyC Offline
          cotty
          @gareth said:
          ...and here I am a few hours later trying to assemble my toolbars the way I have always been accustomed to, and without any success.
          Do you have a screenshot of what you are trying to reach?
          my SketchUp gallery
            Frankly, I like the toolbars handling much more in SU2013. I haven't had a single instance of scrambled toolbars which was a common occurrence in SU8. Like Gareth, I wanted the toolbars on the left to layout as I had them in SU8 but that was an easy thing to do. I made two custom toolbars and placed the tools I wanted on them. Then I set them over on the left edge of the drawing space where I was used to looking for them. It took maybe 5 minutes. The new custom toolbars take up less real estate than in SU8 so I can get more tools in the left hand columns than before.
            The rest of the toolbars went in as usual. I made a screen capture of my SU8 screen and placed the toolbars in SU2013 to match.
            • GarethG Offline
              Gareth
              yep.....the same as Dave's screenshot
              after 9 years of having my toolbars on the left side, it has become instinctive to find what I want quickly and effortlessly
              a good anology is this....I have always owned a car with the indicator arm on the right side of the steering wheel column, my partner owns an Audi and the indicator is on the left, When I drive her car I frequently turn corners with the windscreen wipers on....!! πŸ˜†
              My point is that sometimes it is too hard to retrain the brain....!!
              Anyhow, where do I find how to make Custom Toolbars like Dave's ?
                Gareth, here's how I made my custom toolbars. Forst, I made a screen shot of my SU8 toolbars so I could see the order. I imported that into SU2013 as an image so I could see it without having to look elsewhere. Next, I went to View>Toolbars and turned on all the native toolbars and placed them in the drawing space. Where doesn't matter much. Just group them somewhere so they don't hide the image you've inserted. Click on the New button and create a new toolbar. Give it a name you can remember for a moment or two, like Left Toolbar. Make a second toolbar the same way and call it Right Toolbar. Now you're all set.
                Hold Ctrl and drag each button from it's default toolbar to the appropriate new toolbar. Holding Ctrl will cause the button to be copied instead of moved. When you've got a couple of buttons on each toolbar they can be reshaped to vertical. Continue dragging tools until you have all you want. Close the default toolbars when you're finished with them.
                After you've made the toolbars you can drag them over to the left side next to each other and you're done.
                FWIW, last night I updated my graphics drivers. For some reason after doing that, SU opened at about a quarter of the screen size. I just dragged the window back to normal size and the toolbars were exactly as before. If that had been SU8, the toolbars would have been scrambled. I think folks are crazy if they like SU8's toolbar behavior.
                • GarethG Offline
                  Gareth
                  Thanks Dave πŸ‘ .....I'll give that a try (I'll blame you if the windscreen wipers come on....!! πŸ˜† )
                  Whoever thought that the new Toolbar setup in SU 2013 was a good idea ?
                    Seriously? You've never had scrambled toolbars? And apparently you've never had to help others who did, either. If you did, you'd be thankful for the new toolbars. I'm happy to not have to teach new users how to deal with the scrambled toolbar thing.
                    • GarethG Offline
                      Gareth
                      Yep, I remember having had the scrambling issue a few times in previous SU versions and thought it was my computer's fault when it happened. I don't recall it happening in SU8 though.
                      But I was referring to the Toolbar layout arrangement in 2013 being a bad idea.
                      Anyhow, your idea works brilliantly. Thank you for your advice.
                      I genuinely appreciate your help and I now have a Toolbar layout I am comfortable and familiar with. πŸ‘
                        I don't understand why you think the SU2013 toolbar thing is a bad idea. You can customize the toolbars to display only those tools you need and save real estate for plugin toolbars and you can change the size and proportions of the drawing window without wrecking the toolbar layout. And when you're opening toolbars you don't have to continually hit View>Toolbars to pick each toolbar individually. Who wouldn't want that?
                        • GarethG Offline
                          Gareth
                          Well when you put it that way I am compelled to agree. πŸ˜„
                          Although it is the process, in my view, which is a little inconvenient. But now that I know how to do it (which was fairly simple thanks to your succinct tips) it looks neat and clean...and yes, the Plugin toolbars are now nicely seperated πŸ‘
                          • ken28875K Offline
                            ken28875
                            Dave, I totally agree with you. The new system does fix the scrambled toolbar problem in SU8. However, they removed the "Load saved toolbar" function. One might think, who needs it if SU2013 fix the scrambled toolbars, right? Well, you will need it if you encounter the new issue I talked about when I started this thread. When you click on an icon and move/drag it by mistake, you will lose the toolbar set that the icon belongs to. With "the Load saved toolbar", you can fix that issue by one click of the mouse. Without it, it's kind of time consuming to find the icons and put them back.
                            With the new toolbars handling, I was hoping that SU2013 would keep the "Load saved toolbars" too, therefore we would have the best of both worlds.
                            Have a good one,
                            _KN
                            Follow Your Dreams.
                            • BoxB Offline
                              Taking what Ken is saying ones step further would be exporting your toolbar setup to load on another computer. Or as part of different setups, as with the new "sets" in the SU store plugin.
                              • ken28875K Offline
                                ken28875
                                +1 πŸ‘
                                That would be ideal for people using both work and home computers.
                                Follow Your Dreams.
