    Count / selection count
    3 Posts 3 Posters 1.3k Views 3 Watching
    • onzkiO Offline
      onzki
      Hi guys, is there a way to count selected objects? For example: I have parking slots, (each slot is a component). When I select a part or the area containing these objects, an info feedback will return, something like "100 objects selected". For those familiar with CAD interface, it's the same found on command box.
      Thanks!
      [/hr]Dell Alienware Area-51. SKU 2021 Pro. AutoCAD 2023. Landscape design firm
      • renderizaR Offline
        renderiza
        right click on selection and select entity info which will open a window and at the top you will see how many you have selected.
        [url=https://www.sketchupcode.com/:z3kqsidd]My Extensions ...[/url:z3kqsidd]
          If you want to extract the count of specific objects within a larger selection you need to filter the results.
          A one-liner typed or copy+paste into the Ruby Console +<enter> can so this.
          This example counts all instances of a component named 'parking' within a broader selection:
          c=0;Sketchup.active_model.selection.grep(Sketchup;;ComponentInstance).each{|i|c+=1 if i.definition.name=='parking'};p c;
          If you have several to count en mass like 'Parking', 'parking#1', 'parking#2' etc use a regex test like i.definition.name=~/^[Pp]arking/ to match more than one name...
          If you want to count ALL instances of a given component [with selection] use
          puts(Sketchup.active_model.definitions['parking'].instances.length)
          There are many possibilities ...
