    Dinamic colors or something like that ?
    7 Posts 5 Posters 902 Views 5 Watching
    • H
      hulahopka
      Hi. I see few days ago, some plugin in this forums but I cant remember name and I forgot make bookmark, or maybe even see here 😄 not 100% shure sorry about that.
      Thsi is the thing, I make one heat exchanger spiral, but I wont colored this spiral-tube like heat spread from on side to another. And tha plugin I think make this, I remember it call dinamic but not shure what is next, and icon here on Is look like house or Chart ?
      I make one layer of gradient with photoshop but this is not what I want.
      Are anyone know what Im takling about ?
      And another thing, how I can change for example, If i want make circle on green or red axe, how to change orientation or this circle ? On blue axe go OK. but on other not, so I usual help with make some cube and than use that cune to change orientation and hold shift key. But I see on some youtube tutorials It may be changed but I just dont get how.
      Thankyou for help.
      • cottyC
        cotty
        Maybe SketchUV ($) or UV toolkit?
        my SketchUp gallery
        • H
          hulahopka
          Thank you, will try first with UV toolkit.
            Thankyou for help.
            Perhaps the easiest way to change the orientation of the circle tool is to orbit to a lower point of view. Look more down one axis or the other to get the tool to orient with that axis.
            If you orbit to a viewpoint close to the one displayed, you can easily get the Circle tool to pick up any of the three axis orientations depending upon where in the drawing space you move the cursor. If you get it above the horizon and move it to the left in my example, you'll get red, toward the right and above the horizon, green and below the horizon, blue. Once you have it orientated as you wish, hold Shift to lock that orientation.
            • mitcorbM
              mitcorb
              A gradual change in some value such as color or temperature would be called "Gradient".
              In the Sketchucation Plugin Store by Steve Richey: Gradientator.
              • renderizaR
                renderiza
                Animatex Plugin can animate textures and if you see the second video on the topic there is an example of a cube that changes colors using a gradient image. Here is the link...
                404 Not Found
                (sketchucation.com)
                [url=https://www.sketchupcode.com/:z3kqsidd]My Extensions ...[/url:z3kqsidd]
                • H
                  hulahopka
                  Hi. I will test this suggestions, for orientation I got it now 😄 Other must test on example. Thank you all.
