    How to make Vray show render time
    renderpluginsextensions
    9 Posts 6 Posters 34.0k Views 6 Watching
      mostafa999
      How to make the frame buffer show the time needed to complete a render? mine does not show
      • Z Offline
        Zylescozar19
        Same problem here. Hope that someone could help us.
        • dcauldwellD Offline
          dcauldwell
          When you have rendered your model, in the render window, in the bottom right hand side there is a sort of down 'chevron'. Click on this and you have some options, one of which is 'apply stamp' select this, and next to it there is a % symbol. If you select this you can add various fields to the stamp such as time to render, version number etc.
          David
          Sketchup 2017
          (vray 2.00)
          • V Offline
            valerostudio
            Here is a visual - you can add a variety of stamps as well.
            • dkendigD Offline
              dkendig
              No, we don't estimate the amount of time needed to complete a render.
              Devin Kendig
              Developer
                dcauldwell
                Ooops! my misreading of the question. Vray only shows the time it has taken to render, and not how long it is going to take.
                Sketchup 2017
                (vray 2.00)
                • V Offline
                  valerostudio
                  Oh, yep I misread that as well. The answer is no but VR4SU2.0 did bring the progress bar back, so you have some indication of where you are in the process.
                  • Z Offline
                    Zylescozar19
                    Thanks for this. πŸ˜„
                      janu4869
                      Despite this missunderstanding, im looking for this info actually... thank you Sir πŸ˜„
