    Problem with face.normal directions...help!
    10 Posts 5 Posters 814 Views 5 Watching
    • renderizaR Offline
      renderiza
      In the graph below I can work out if a face is normal is facing on the direction specified in the first four examples. But I don't know how to evaluate if a face normal is facing giving the directions specified in the last four graph examples. Any help will be Appreciated!
      http://s11.postimg.org/jj4tvgdki/question.jpg
      http://s11.postimg.org/ohsc9zhdd/question.jpg
      If my problem is not clear please let me know I will try to explain it better...cheers!
      [url=https://www.sketchupcode.com/:z3kqsidd]My Extensions ...[/url:z3kqsidd]
        renderiza
        I think this might be it...Sorry not very good at math πŸ˜• πŸ˜’
        Top Right = f1nx > 0 and f1ny > 0
        Top Left = f1nx < 0 and f1ny > 0
        Button Right = f1nx > 0 and f1ny < 0
        Button Left = f1nx < 0 and f1ny < 0
        • Chris FullmerC Offline
          I'm not quite sure I understand, but I think I might have something helpful.
          Find the dot product of the face's normal and the x_axis. If its a positive number, then the face normal is in the positive x range. Do the same for the y and z (if you need z). Try this code snippet, it will tell you if the face normal is pointing in a positive or negative x,y,z direction. Or it will tell you if the face normal is perpendicular to the model x,y, or z axis.
          face=Sketchup.active_model.selection[0]
          norm = face.normal
          dot_products = {}
          dot_products["x"] = norm.dot(X_AXIS)
          dot_products["y"] = norm.dot(Y_AXIS)
          dot_products["z"] = norm.dot(Z_AXIS)
          dot_products.each do |key, value|
          case
            when value < 0
              puts "#{key} direction is a negative direction"
            when value == 0
              puts "#{key} direction is perpendicular to the #{key} axis"
            when value > 0
              puts "#{key} direction is a positive direction"
          All my Plugins I've written
            renderiza
            Thanks Chris Fullmer your example does the job as well.
            Here is another example that will select faces that are pointing to the top right...
            model = Sketchup.active_model
            sel = model.selection
            ents = model.active_entities
            faces = ents.grep(Sketchup;;Face)
            faces.each do |face|
            	f1nx = face.normal.x
            	f1ny = face.normal.y
            	#Face looking top right
            	if f1nx > 0 and f1ny > 0
            		sel.add face
            • tt_suT Offline
              tt_su
              That image in the OP isn't loading for me...
                now?
                  nope, not yet. It never showed for me either, I had to click on it to follow the link.
                    No.
                    The image links aren't working... πŸ˜•
                    http://s11.postimg.org/z4m5fepiq/question.jpg
                    Above is http://s11.postimg.org/z4m5fepiq/question.jpg NOT these...
                    http://s11.postimg.org/jj4tvgdki/question.jpg]
                      I see it. NA NA NA-NA NA
                        Back to the question...
                        NorthEast Quadrant: normal.y>0 normal.x>0
                        SouthEast Quadrant: normal.y<0 normal.x>0
                        SouthWest Quadrant: normal.y<0 normal.x<0
                        NorthWest Quadrant: normal.y>0 normal.x<0
                        As you said:
                        Due North: normal.y==1 normal.x==0
                        Due East: normal.y==0 normal.x==1
                        Due South: normal.y==-1 normal.x==0
                        Due West: normal.y==0 normal.x==-1
                        Exactly Vertical: normal.z==0
                        Upwards Facing: normal.z>0
                        Downwards Facing: normal.z<0
                        Exactly Up: normal.z==1
                        Exactly Down: normal.z==-1
