    Multiple segment editor plugin
    17 Posts 4 Posters 1.1k Views 4 Watching
    • onzkiO Offline
      onzki
      Hi, I'm curious if we have a plug in where the user can select multiple arc or circles and specify its segments at once?
      The native sketchup only allows one edit per selection via entity info (segments). The problem with this is the time factor, say if there's 20 circles or arcs- it would be better (IMHO) if the user can select them all and then specify the segments he wanted instead of selecting and editing one by one.
      Thanks! ๐Ÿ˜„
      http://img199.imageshack.us/img199/995/ymtb.png
      [/hr]Dell Alienware Area-51. SKU 2021 Pro. AutoCAD 2023. Landscape design firm
      • mitcorbM Offline
        mitcorb
        I am sure you are familiar with Fredo6's Bezier Spline suite. You did not mention if you were using it. If you right click on a selection and get Polyline Segmentor, or Polyline Divider, it may be simpler but not necessarily multi selection as you wish. Just thought I would mention, if it might help. There may be a creative way to use ThomThom's selection tool to accomplish this?
        • onzkiO Offline
          onzki
          Thanks for the reply. Yes I have that one and it's very useful. However, like what you mentioned, it doesn't have the option that I'm currently looking for. Thanks again for the suggestion.
          • mitcorbM Offline
            mitcorb
            Hi, onzki:
            I still think that this idea is very useful, and not so esoteric or specialized. The tool would still have to look at each separate entity one by one and perform the desired operation similar to an operation that simplifies a mesh- a polyreducer- or polymultiplier as the case may be.
            The difference is that the tool may be able to do it more quickly, since it is repetitive. A problem may arise if the entity is connected to other geometry. Just some thoughts. I am sure there may be reasons why not.
              If I good understand that mean that each segment is resized ?
              So it's also separated object
              So make all separated group with Loose Geometry by Chris Fullmer
              Group to Component by Thomthom
              Then Axes tool by Thomthom for have Center of selection Box for each component
              rest to find the plug for a "relative resizing" ๐Ÿ˜„
              Seems Chris Fullmer has that ๐Ÿ˜„
              Scale and Rotate Multiple
              Et voilร  ๐Ÿ’š
              If it's for change the number of segments it's another story! ๐Ÿ˜„
                Maybe http://sketchucation.com/resources/pluginstore?pln=TIG_equalsegs to draw them like that initially OR my http://sketchucation.com/resources/pluginstore?pln=ArcCurve_set_segments to fix them later ? It has a Ruby Console tool TIG.changearcsegments 64 using the new API method and a Plugins menu item in the newest version...
                  About the number of segments
                  Curiously only Ruby console works and only for the Arcs!
                  Circles are ignored! ๐Ÿ˜ฒ
                  Menu makes nothing!
                  (tested on V7 free)
                    Works fine for me in both v8 & v2013.
                    From menu OR Console for both Arcs & Circles
                    Any Ruby Console errors?
                    It should change Arcs & Circles - BUT of course connected geometry can prevent changes being made - just like with Entity Info's limitations.
                    Try it on lone a lone unconnected Circle and report back...
                      For one a several arcscircles selected : all works fine in the Ruby Console!
                      For one a several arcscircles selected nothing happen with the menu!
                      For one a several circles selected this error is happening with Ruby Console
                      Error: #<NoMethodError: C:/Program Files/Google/TGoogle SketchUp 7/Plugins/ArcCurve-set_segments=.rb:65:in set_segments=': undefined method is_polygon?' for #Sketchup::ArcCurve:0x1104e140>
                      For one a several circles selected nothing happen with the menu!
                      All this is very curious because seems in the old past all worked fine ๐Ÿ˜„
                      Maybe the new API ? ๐Ÿ˜„
                      (Tested with Su 7 free)
                        ๐Ÿ’ญ
                        .is_polygon?
                        was introduced in v8 ?
                        This checks if a looped curve is a polygon OR a circle...
                        I had made an API addition that was dropped when it became part of the new API...
                        So if you are trying to work on circles, then sadly it's >=v8 use only then...
                        UNLESS you also include this attached rb file in your <v8 Plugins folder!!!
                        [mod=:1cut554m]Removed the attachment - better version in next few posts...
                        TIG[/mod:1cut554m]
                          with the new file test added
                          Must have the 2 rb files ArcCurve-set_segments=.rb and ArcCurveTests.rb installed ?
                          (it that I made)
                          2 circles and an arc-circle selected
                          Menu : Nothing happen
                          and with the ruby console
                          nothing change and this error message
                          Error: #<ArgumentError: C:/Program Files/Google/TGoogle SketchUp 7/Plugins/ArcCurve-set_segments=.rb:61:in `is_loop?': wrong number of arguments(1 for 0)>
                          for only an arc-circle selected
                          same error message on the ruby console
                            OK, another issue is .is_loop? is causing problems.
                            I've bodge up a new version - test it and report back...
                            It should now be compatible with this tool, other tools and v7 & other versions ๐Ÿ˜’
                            ArcCurveTests.rb
                              You were very efficicient! ๐Ÿ˜Ž
                              All is perfect! Menu or / and console ๐Ÿ‘
                              Works even you choose other things inside the selection! ๐Ÿ‘
                              (tested on SU 7 free)
                              Bravo! โ˜€
                              http://blog.lesoir.be/saturdaywinefever/files/2013/07/Moet-Chandon-524x965.jpg
                                I've now incorporated this updated ArcCurveTests.rb in the 'segemnt-setting' tool's PluginStore RBZ for the tool, as it works 'backwards' down to v7...
                                • onzkiO Offline
                                  onzki
                                  Thanks a lot for looking at this post and sharing your time generously for another good plugin, what's the specific plug in name again? Thanks, cheers! ๐Ÿ‘
                                    • onzkiO Offline
                                      onzki
                                      I tried it.. wow, this is amazing. I can set it endlessly, from high to low and vice versa ๐Ÿ˜„ Thanks a lot!
