    Multiple segment editor plugin
    17 Posts 4 Posters 1.3k Views 4 Watching
      If I good understand that mean that each segment is resized ?
      So it's also separated object
      So make all separated group with Loose Geometry by Chris Fullmer
      Group to Component by Thomthom
      Then Axes tool by Thomthom for have Center of selection Box for each component
      rest to find the plug for a "relative resizing" πŸ˜„
      Seems Chris Fullmer has that πŸ˜„
      Scale and Rotate Multiple
      Et voilΓ  πŸ’š
      If it's for change the number of segments it's another story! πŸ˜„
        Maybe http://sketchucation.com/resources/pluginstore?pln=TIG_equalsegs to draw them like that initially OR my http://sketchucation.com/resources/pluginstore?pln=ArcCurve_set_segments to fix them later ? It has a Ruby Console tool TIG.changearcsegments 64 using the new API method and a Plugins menu item in the newest version...
          About the number of segments
          Curiously only Ruby console works and only for the Arcs!
          Circles are ignored! 😲
          Menu makes nothing!
          (tested on V7 free)
            Works fine for me in both v8 & v2013.
            From menu OR Console for both Arcs & Circles
            Any Ruby Console errors?
            It should change Arcs & Circles - BUT of course connected geometry can prevent changes being made - just like with Entity Info's limitations.
            Try it on lone a lone unconnected Circle and report back...
              For one a several arcscircles selected : all works fine in the Ruby Console!
              For one a several arcscircles selected nothing happen with the menu!
              For one a several circles selected this error is happening with Ruby Console
              Error: #<NoMethodError: C:/Program Files/Google/TGoogle SketchUp 7/Plugins/ArcCurve-set_segments=.rb:65:in set_segments=': undefined method is_polygon?' for #Sketchup::ArcCurve:0x1104e140>
              For one a several circles selected nothing happen with the menu!
              All this is very curious because seems in the old past all worked fine πŸ˜„
              Maybe the new API ? πŸ˜„
              (Tested with Su 7 free)
                πŸ’­
                .is_polygon?
                was introduced in v8 ?
                This checks if a looped curve is a polygon OR a circle...
                I had made an API addition that was dropped when it became part of the new API...
                So if you are trying to work on circles, then sadly it's >=v8 use only then...
                UNLESS you also include this attached rb file in your <v8 Plugins folder!!!
                [mod=:1cut554m]Removed the attachment - better version in next few posts...
                TIG[/mod:1cut554m]
                  with the new file test added
                  Must have the 2 rb files ArcCurve-set_segments=.rb and ArcCurveTests.rb installed ?
                  (it that I made)
                  2 circles and an arc-circle selected
                  Menu : Nothing happen
                  and with the ruby console
                  nothing change and this error message
                  Error: #<ArgumentError: C:/Program Files/Google/TGoogle SketchUp 7/Plugins/ArcCurve-set_segments=.rb:61:in `is_loop?': wrong number of arguments(1 for 0)>
                  for only an arc-circle selected
                  same error message on the ruby console
                    OK, another issue is .is_loop? is causing problems.
                    I've bodge up a new version - test it and report back...
                    It should now be compatible with this tool, other tools and v7 & other versions πŸ˜’
                    ArcCurveTests.rb
                      You were very efficicient! 😎
                      All is perfect! Menu or / and console πŸ‘
                      Works even you choose other things inside the selection! πŸ‘
                      (tested on SU 7 free)
                      Bravo! β˜€
                      http://blog.lesoir.be/saturdaywinefever/files/2013/07/Moet-Chandon-524x965.jpg
                        I've now incorporated this updated ArcCurveTests.rb in the 'segemnt-setting' tool's PluginStore RBZ for the tool, as it works 'backwards' down to v7...
                        • onzkiO Offline
                          onzki
                          Thanks a lot for looking at this post and sharing your time generously for another good plugin, what's the specific plug in name again? Thanks, cheers! πŸ‘
                          [/hr]Dell Alienware Area-51. SKU 2021 Pro. AutoCAD 2023. Landscape design firm
                            404 Not Found
                            (sketchucation.com)
                            • onzkiO Offline
                              onzki
                              @tig said:
                              404 Not Found
                              (sketchucation.com)
                              I tried it.. wow, this is amazing. I can set it endlessly, from high to low and vice versa πŸ˜„ Thanks a lot!
