    [Plugin] Layers Panel 1.2.1
    673 Posts 110 Posters 316.3k Views 110 Watching
    • ToboboT Offline
      Tobobo
      @jiminy-billy-bob said:
      Hey guys, how about choosing what layers to render ? πŸ˜„
      Got it working with at least Vray, Kerkythea, and Maxwell suite.
      That is a very interesting concept.
      It means you could using to hide walls etc
      Toby
      Philippians 4:13
      • jiminy-billy-bobJ Offline
        jiminy-billy-bob
        It means the plugin will hide/unhide chosen layers when you hit the render button, without actually hidding/showing them. So you could have heavy vegetation layers sent to the renderer, but never activated in SU's viewport.
        • tt_suT Offline
          tt_su
          Oh? Now that sounds mighty interesting.
            jiminy-billy-bob
            Yeah, and that's pretty simple :
            • Start operation with UI disabled
            • Hide/unhide chosen layers (But UI is disabled, so their visibility is not actually changed)
            • Trigger render (like "VRayForSketchUp.launch_vray_render")
            • Revert back layers visibility
            • Commit operation
            πŸ˜„
            • Bob JamesB Offline
              Bob James
              Totally outstanding plugin πŸ‘ πŸ‘
              Would it be possible to add the ability to delete a layer into the current layer?
              Example:
              I have layer 5 chosen as the current default layer.
              I want to put all the stuff in layer 8 into layer 5
              I need the option to select 1. delete completely, 2. delete to layer 0, and 3. delete to current layer.
              The first two exist (the red garbage can and the green garbage can)
              Now I'd like a "blue" garbage can "delete to current layer" πŸ˜„
              Once again: Outstanding Plugin
                Bob James
                While using Ctrl-z to undelete portions of the model that I have just deleted, I get this dialog.
                  jiminy-billy-bob
                  Noted bob about deleting to active layer.
                  Not sure about the undo problem, though. Do you get this every time ?
                    jiminy-billy-bob
                    BOOM !
                    Choose what layer to render ! πŸ‘
                    [screenr:t24aadah]OHcH[/screenr:t24aadah]
                    Works with Vray, Maxwell, Kerkythea and Indigo. I'm working with Tomasz to get Thea to support this feature.
                    It still needs some finishing, but the release is not far πŸ˜‰
                    • ToboboT Offline
                      Tobobo
                      BOOM !
                      Well done!!! I cant wait to have a crack πŸ‘
                      Toby
                      Philippians 4:13
                        jiminy-billy-bob
                        New version 0.4 beta !
                        Changelog :
                        • Adds the ability to choose which layers to render (Works with Vray, Maxwell, Indigo, and Kerkythea)
                        • Fix bug when having too many layers
                        • The dialog now remembers its size and position when closed
                        • Fix focus jumping at the top of the dialog
                        Download in the plugin store !
                        • K Offline
                          kirill2008
                          I won't be original, just want to say: it is a great plugin! πŸ‘ Many thanks for it!
                            jiminy-billy-bob
                            @kirill2008 said:
                            I won't be original
                            You don't have to, it's always nice to hear that πŸ˜‰
                            • U Offline
                              Ulimann
                              Hallo Jiminy
                              Great plugin , installed the update and get the resulting screen on activation.
                              I am running Windows 7 64 SU 8 PRO.
                                jiminy-billy-bob
                                Can you delete everything concerning Layers Panel in your plugin folder, and reinstall it ?
                                Plugins/jbb_layers_panel.rb
                                • U Offline
                                  Ulimann
                                  Thanks for the quick reply,did as you suggested its up and running.
                                  • sadyoS Offline
                                    sadyo
                                    Great Plugin... (y)
                                    waiting for Render feature to work with Thea Render
                                      jiminy-billy-bob
                                      Actually, if it works with Thea on day, it'll behave differently. You will probably have an option directly inside Thea allowing you to choose if you want to render with Layers Panel feature or not. But you won't render from within Layers Panel as you do with Vray/Maxwell/etc. This is due to the way Thea is designed. I can't trigger the render from my plugin.
                                      I gave evrything to Tomasz to make it work, the ball is on his side now πŸ˜‰ So if you badly want this feature, you should get in touch with him !
                                      • doush-007D Offline
                                        doush-007
                                        Great plugin...it must absolutely replaced the layer window in the next version of sketchup..thanks a lot for this plugin 😍
                                        • JQLJ Offline
                                          JQL
                                          Jiminy great plugin and great news on Thea!
                                          Is it possible that my layer groups have been wiped out after a purge?
                                          Best regards,
                                          JQL
                                          www.casca.pt
                                          Visit us on facebook!
                                            jiminy-billy-bob
                                            That's not possible with a purge. But it may be something else... I have no idea what, though. Did you do anything unusual around the time the group were wiped ?
                                            • 6
                                            • 7
                                            • 8
                                            • 9
                                            • 33
                                            • 34
                                            • 7 / 34
