    [Plugin] Layers Panel 1.2.1
    673 Posts 110 Posters 309.6k Views 110 Watching
    • SolarwiseLLCS Offline
      SolarwiseLLC
      Jiminy-Billy-Bob,
      First off let me say I love this plugin.
      Recently, my layer's panel has become unresponsive in one of my drawings. (This is true for SU13 and SU14) Unresponsive in that the layers do not toggle on or off anymore. This one file was working. I saved multiple copies of it and now none of them work properly. Other files/drawings work. I even created a new drawing. Created a new layers list and pasted the original drawing in layer by layer. This worked until I closed the drawing and restarted my computer. Is there a a easy fix? I could have moved or removed a file when I was trying out SU 14.
      Layers Panel 1.03
      I'm using SU 13, but have 14 installed
      Windows 8
      I have other layer managing plugin installed (Conflict?) They aren't interfering with my other files.
      • jiminy-billy-bobJ Offline
        jiminy-billy-bob
        Could you send me the file by PM?
        What are the other layer managing plugins?
          jiminy-billy-bob
          @solarwisellc said:
          So something strange has happen since I posted. I continued to work on the drawing "DD1", but stopped using the Layer Panel plugin. I was just using the Layers Window. After a while I checked the Layers Panel and it had started working again. I noticed all the folders had been removed and it was now just a list of layers.
          Drawing DD1.1 still shows the folders and is still unresponsive.
          Addition layer plugins:
          Layers Manager (I think that is it)
          I'm not sure what caused the issue, but here is how to solve it:
          • Install Aerilius' AttributeInspector
          • Open it
          • Click on "jbb_layerspanel"
          • Delete all the " group[22]=null&group[23]=22&layer...." stuff (Just select and delete)
          • Reopen Layers Panel, you should loose all the sorting and groups, but it should work fine.
          http://i.imgur.com/xqYYqWb.png
            SolarwiseLLC
            • Open it
            Thanks. I will try this. Will I be able to regroup afterwards?
              jiminy-billy-bob
              Of course, LP should behave normally after this. It's a fresh start.
              • sadyoS Offline
                sadyo
                Hi mr.Bob
                Seem like the LP 1.0.3 have problems when I updated TT_Lib 2.9.9 ❓
                http://s30.postimg.org/mgwf0y5fl/hh2.jpg
                I'm using Sketchup 2014 pro_Win8.1-64bit
                  jiminy-billy-bob
                  sadyo > Please see:
                  @tt_su said:
                  @vremennyi said:
                  Or is this SU bug and about this should think SU developers?
                  Yes - it's our fault. 😞 We're working on a fix.
                  • tt_suT Offline
                    tt_su
                    That's a co-incidence. When you launch SketchUp via a SKP file that is located on a drive different from where SketchUp is installed something gets messed up in SketchUp Ruby. Launch SketchUp first, then open your file - that's the workaround until we release a fix.
                      SolarwiseLLC
                      After resetting the folders as you outlined. I was able to regroup and work in the file successfully. After closing SU and restarting my computer, the layers panel stop being responsive in that file. After working in the same file, using just the layers window, the layers panel reset the folders/grouping by itself. Once it reset itself, the layers panel worked, but the folders/grouping were deleted. Wondering if it's the plugin or my file.
                        jiminy-billy-bob
                        I'm investigating with the file you gave me. This is weird.
                        Do you actively use Didier's Layers Manager, or is it just installed?
                        To you import geometry, or copy/paste between instances?
                          SolarwiseLLC
                          I do actively use the Didler's Layer Manager. When transferring geometry, I usually copy and paste.
                            amis
                            Hi, Jiminy! There's a problem when I use cyrillic font to rename new layer - some codes appear instead of cyrillic letters. Although it didn't happen before (win XP, SU 2013) Got any ideas?
                              amis
                              amis > You're not the first to tell me this. I forgot, thanks to remind me, I'll take a loot at it.
                              So if I understand right, it works fine on winXP with SU2014, what is yout windows version now, and SU version?
                              we didn't understand each other properly) Win XP, SU 2013 that's for now
                                jiminy-billy-bob
                                New version 1.0.4 !
                                Changelog :
                                • Added better feedback when sorting multiple layers/groups at once
                                • Added support for Podium V2+
                                • Fixed support for Indigo
                                Download in the plugin store !
                                • kenK Offline
                                  ken
                                  I open Sketchup files on my travel USB HD from XnView all the time. So are you telling me, the safest way to open Sketchup files is from Sketchup and not a viewer?
                                  IF so, this could explain a lot.
                                  Thanks for your reply.
                                  Ken
                                  • tt_suT Offline
                                    tt_su
                                    Yes, if you use plugins then until we get the fix released you're better of starting SketchUp first, then open the files from SketchUp. Apologies for the inconvenience.
                                      jiminy-billy-bob
                                      Do you have an ETA for the fixed release?
                                      • tt_suT Offline
                                        tt_su
                                        Afraid not. WIP.
                                          jiminy-billy-bob
                                          Layers Panel reached 300 unique daily users
                                          (as far as I can see, there are probably more if there are multiple users on a single IP adress)
                                          A big thanks to all of you to motivate me pushing this plugin further and further! πŸ˜„
                                          It wouldn't be what it is today if not thanks to all your feedback and ideas.
                                          http://i.imgur.com/55yXgRP.png
                                          • Bob JamesB Offline
                                            Bob James
                                            I still cannot undo without this appearing keeping the undo from happening:
                                            Undo Layers Panel ID
                                            • 22
                                            • 23
                                            • 24
                                            • 25
                                            • 26
                                            • 33
                                            • 34
                                            • 24 / 34
