    [Plugin] Layers Panel 1.2.1
    673 Posts 110 Posters 309.7k Views 110 Watching
    • vremennyiV Offline
      vremennyi
      After reinstalling SU Make, cleaning directory in %AppData% I have same error...
        babak
        First, thank you for the plugin !
        I have the same issue as vremennyi. Sketchup 2014 pro and windows 7. The plugin works well except when I try to launch sketchup by clicking a file stored on another drive (D:) or network. Then it cannot find winAPI.so.
        It could explain vremennyi problem on his laptop.
        • tt_suT Offline
          tt_su
          This is a known issue in SketchUp 2014. 😞
          • jiminy-billy-bobJ Offline
            jiminy-billy-bob
            I spoke to the Trimble guys, and it seems to be an issue with SU2014 itself. In some cases, ruby fails to load properly, when double-clicking on a file.
            There's not much I can do... Trimble is working to fix it.
            Meanwhile, try to open Sketchup, and then open your files with "Files > Open".
            EDIT : Oh well, I'm too slow 😄
              jiminy-billy-bob
              vremennyi, yinliangxxxx, babak,
              Try replacing the file "Plugins/jbb_layers_panel/layers_panel.rb" by the attached one (see below), and tell me if it works.
              layers_panel.rb
                babak
                %(#004080)[jiminy-billy-bob, thank you for your quick answer.
                I still get the following error while launching from d:\ or network.]
                Erreur de chargement du fichier C:/Users/vfr/AppData/Roaming/SketchUp/SketchUp 2014/SketchUp/Plugins/jbb_layers_panel/layers_panel.rb
                Error: #<LoadError: cannot load such file -- dl>
                C:/Program Files (x86)/SketchUp/SketchUp 2014/Tools/RubyStdLib/Win32API.rb:5:in require' C:/Program Files (x86)/SketchUp/SketchUp 2014/Tools/RubyStdLib/Win32API.rb:5:in <top (required)>'
                C:/Users/vfr/AppData/Roaming/SketchUp/SketchUp 2014/SketchUp/Plugins/jbb_layers_panel/layers_panel.rb:32:in require' C:/Users/vfr/AppData/Roaming/SketchUp/SketchUp 2014/SketchUp/Plugins/jbb_layers_panel/layers_panel.rb:32:in rescue in module:JBB_LayersPanel'
                C:/Users/vfr/AppData/Roaming/SketchUp/SketchUp 2014/SketchUp/Plugins/jbb_layers_panel/layers_panel.rb:28:in <module:JBB_LayersPanel>' C:/Users/vfr/AppData/Roaming/SketchUp/SketchUp 2014/SketchUp/Plugins/jbb_layers_panel/layers_panel.rb:5:in <top (required)>'
                C:/Program Files (x86)/SketchUp/SketchUp 2014/Tools/extensions.rb:197:in require' C:/Program Files (x86)/SketchUp/SketchUp 2014/Tools/extensions.rb:197:in load'
                C:/Users/vfr/AppData/Roaming/SketchUp/SketchUp 2014/SketchUp/Plugins/jbb_layers_panel.rb:39:in register_extension' C:/Users/vfr/AppData/Roaming/SketchUp/SketchUp 2014/SketchUp/Plugins /jbb_layers_panel.rb:39:in <top (required)>'
                  jiminy-billy-bob
                  Well, in that case we just need to wait for trimble to fix this.
                  • U Offline
                    unclex
                    Error Loading File C:/Users/Administrator/AppData/Roaming/SketchUp/SketchUp 2014/SketchUp/Plugins/jbb_layers_panel/layers_panel.rb
                    Error: #<LoadError: cannot load such file -- Win32API>
                    C:/Users/Administrator/AppData/Roaming/SketchUp/SketchUp 2014/SketchUp/Plugins/jbb_layers_panel/layers_panel.rb:19:in require' C:/Users/Administrator/AppData/Roaming/SketchUp/SketchUp 2014/SketchUp/Plugins/jbb_layers_panel/layers_panel.rb:19:in module:JBB_LayersPanel'
                    C:/Users/Administrator/AppData/Roaming/SketchUp/SketchUp 2014/SketchUp/Plugins/jbb_layers_panel/layers_panel.rb:5:in <top (required)>' E:/Trimble/Sketchup.14/Tools/extensions.rb:197:in require'
                    E:/Trimble/Sketchup.14/Tools/extensions.rb:197:in load' C:/Users/Administrator/AppData/Roaming/SketchUp/SketchUp 2014/SketchUp/Plugins/jbb_layers_panel.rb:39:in register_extension'
                    C:/Users/Administrator/AppData/Roaming/SketchUp/SketchUp 2014/SketchUp/Plugins/jbb_layers_panel.rb:39:in `<top (required)>'
                    it's same problem
                    su2014en @ win7x64chinese
                    so I guess, that's something about system, Trimble had better fix it
                      tony bombata
                      interestingly, if you pin a file to sketchup 2014, and launch from the taskbar jumplist, it will open without errors - dont know if that helps
                        jiminy-billy-bob
                        Here is a short video showing how the render feature works.
                        • unclebimU Offline
                          unclebim
                          @unclebim said:
                          @jiminy-billy-bob said:
                          @unclebim said:
                          @unclebim said:
                          1. Not sure whether since ver. 0.4 or 0.5 but in both SU 8 and SU 2013 Edit->Paste and Ctrl+V do not work, Edit->Paste in place works though. Removing the plugin files from SU Plugins folder resolved the problem in both SU 8 and SU 2013. Also renaming layers in the native SU Layers window sometimes caused bugsplat with the plugin installed in SU 2013.
                          Weird. Does it work when Layers Panel is installed but closed ?
                          1. Well it does happen no matter whether Layers Panel is open or closed. What happens is that you can see the pasted object shortly on the screen and then it disappears and the move tool cursor reverts back to the formally active tool. I tried this with groups and components and with ungrouped geometry. The problem occurs when the pasted object requires the creation of a new layer that does not exist in the file already. If I make a layer with the same name that the pasted object is on then it can be pasted. Although I have a problem pasting a nesting group in Layer 0 and I have no problem pasting the nested groups together (also on Layer 0). Moving the same nesting group on a newly created (after Layers Panel installation) layer does not help. Making the group a component also.
                          I can still report the same problem with both SU 2013 and SU 2014. Here are the respective error reports:
                          Error: #<TypeError: reference to deleted Entity>
                          C:/PROGRA~2/SketchUp/SKETCH~1/Plugins/jbb_layers_panel/rb/methods.rb:48:in get_attribute' C:/PROGRA~2/SketchUp/SKETCH~1/Plugins/jbb_layers_panel/rb/methods.rb:48:in IdLayer'
                          C:/PROGRA~2/SketchUp/SKETCH~1/Plugins/jbb_layers_panel/rb/observers.rb:73:in onLayerAdded' C:/PROGRA~2/SketchUp/SKETCH~1/Plugins/#WorkPlane.rb:274:in call'
                          C:/PROGRA~2/SketchUp/SKETCH~1/Plugins/jbb_layers_panel/rb/observers.rb:73:in onLayerAdded' C:/PROGRA~2/SketchUp/SKETCH~1/Plugins/jbb_layers_panel/rb/methods.rb:48:in call'
                          C:/Users/Bim/AppData/Roaming/SketchUp/SketchUp 2014/SketchUp/Plugins/jbb_layers_panel/rb/methods.rb:48:in get_attribute' C:/Users/Bim/AppData/Roaming/SketchUp/SketchUp 2014/SketchUp/Plugins/jbb_layers_panel/rb/methods.rb:48:in IdLayer'
                          C:/Users/Bim/AppData/Roaming/SketchUp/SketchUp 2014/SketchUp/Plugins/jbb_layers_panel/rb/observers.rb:73:in block in onLayerAdded' -e:1:in call'
                          Thank you again for this great plugin, I would love to use it but for the reported problem.
                            jiminy-billy-bob
                            Oh, I thought I had this fixed. I'll take a look at it.
                              jiminy-billy-bob
                              Dan Rathbun wrote this fix. Drop it in the "Tools" folder and tell me if it works.
                              !_fix_ruby_startup.rb
                              EDIT : It's for the startup issue.
                              • JQLJ Offline
                                JQL
                                Hi Jiminy,
                                Great updates! The problem is, you keep giving us more, we keep asking for more...
                                In SU Layers window we can set color to individual layers but not to a group of layers. Wich made me think that with your plugin this would be great!
                                We could change the color of a group and change all the layers inside it or window select some layers, then changing one, could change all. Maybe selecting a bunch of layers and make all layers same color from the active layer...
                                Anyway, there might be a way of doing this already that I'm unaware of?
                                Thanks again, this plugin should be built in SU core...
                                JQL
                                www.casca.pt
                                Visit us on facebook!
                                  Good point. I think donations are in order for this great plugin.
                                  passes hat around
                                    jiminy-billy-bob
                                    It's coming! 😄
                                    TT > Thanks a lot for your generous donation, that's very much appreciated 😉
                                      jiminy-billy-bob
                                      New version 1.0.2 !
                                      Changelog :
                                      • All selected layers are now sorted together
                                      • Added shift-click for multiple selection
                                      • Fixed issue when copy/pasting from another instance creates a new layer
                                      • Fixed minimize/maximize
                                      Download in the plugin store !
                                        ckho1985
                                        Have to praise this tool!! working on big projects and having loooooooooong list on the SU layers is just a pain.
                                        Notice you have added a render icon for different engines on your tool. Artlantis is not there…. doesn't affect my work. but at first i though it was a miracle button to press.
                                        working on Mac machine. works okay, not as smooth as you show it
                                          jiminy-billy-bob
                                          Can't you already choose which layer you want to render in Artlantis?
                                          What's not smooth on Mac? Can you do a small video?
                                          • tt_suT Offline
                                            tt_su
                                            I just noticed that 1.0.2 doesn't update the WebDialog when you add/remove layers via the WebDialog. The model layers are created - it's just the UI doesn't.
                                            Adding layer-groups updates the UI though.
                                            • 20
                                            • 21
                                            • 22
                                            • 23
                                            • 24
                                            • 33
                                            • 34
                                            • 22 / 34
