    VRay output problem
    renderpluginsextensions
    3 Posts 2 Posters 470 Views 2 Watching
    • E Offline
      erik411
      So I have my model ready to render and I switch off override layout so I can get the entire layout scene. However, every time I try to render it, I get only a rendered center section of the layout. Does anyone know how to fix this to get the entire layout?
      • V Offline
        valerostudio
        Override viewport unchecked will render the view that is currently displayed in SketchUp at the same resolution at the screen resolution. If you have it checked and have not clicked Get view aspect, then you will end up with a cropped portion of your SketchUp view.
        • E Offline
          erik411
          Yup was match photo... I was able to delete the photo, revert to the same camera view and it worked. So weird, it was starting to frustrate me a bit.
