    How to make same diameter ?
    16 Posts 4 Posters 956 Views 4 Watching
    • E Offline
      erzane
      I would like to resize the pipe A with keeping all proportion for having the same diameter than the pipe B, like that I could glue them perfectly.
      but with this tool I cannot resize forms precisely how I want
      do you have an idea ?
      • cottyC Offline
        cotty
        Do you want to scale the whole pipe or only the bottom face?
        • For the whole pipe, you can use the tapemeasure tool in that group/component to scale the diameter to the desired value
        edit:
        • or do you want a smooth transition? This can be done with curviloft...
        edit2:
        • If the bottom circle is still a circle, you can change the radius in the element information window...
        my SketchUp gallery
        • cottyC Offline
          cotty
          See this screencast...
          (I have to remeber to install the english version of SU 😕 )
          my SketchUp gallery
          • E Offline
            erzane
            thanks for your reply
            -for the whole pipe
            I tryed to do the same as that video but I cannot succeed to rescale my pipe
            http://www.youtube.com/watch?v=eXh6y5b0pdg
            -about edit2:
            how did you do for having exact radius information of the circle ?
            I did ''right clic'' entity infos, but it don't gave me the radius
            because if I calculate radius with the TMT it rescale the pipe but still to be
            a difference between both each time I try
            p.s.
            -is curviloft free ?
            • cottyC Offline
              cotty
              @erzane said:
              your link dosen't work
              pls see my edit
              The link works fine for me...
              To edit the radius, you have to select only the circle, not the face! (And it will only work if it is a "real" SU circle)
              my SketchUp gallery
              • E Offline
                erzane
                pls see my edit
                p.s. if I mesure the radius with the TMT tool for the figure B = 2,04m
                the one of the figure A is 1,78m,
                so I rescale B, and it beginn 2,04 , so it's ok
                but when I mesure the A radius again, it beginn 2,34m ...
                very strange
                • cottyC Offline
                  cotty
                  Curviloft is free, but you could (should?!) use the donate button if you find the plugin useful...
                  my SketchUp gallery
                  • E Offline
                    erzane
                    ok, I see
                    now I succeeded to rescale the ''circle''
                    by changing infos of the radius on the entity windows
                    so it's a first step 😆
                    but for rescale the whole pipe
                    it still doesn't work
                    • cottyC Offline
                      cotty
                      pls see my edit
                      very strange
                      Make shure that both pipes are in separate group and scale only one of them (while in edit mode of one of them)!
                      For other people it will be difficult to follow this topic if you change a lot in older posts, so it would be better to reply with a new post instead...
                      my SketchUp gallery
                      • E Offline
                        erzane
                        ok I see
                        my two pipes weren't separates components
                        so that's certainly why the issue appears
                        edit:
                        now I created 2 components A & B
                        but it still don't work
                        • E Offline
                          erzane
                          ok, I quote this time
                          so.. I succeeded to do it finally
                          the problem was that I had 2 components
                          (notion of ''group'' I never use it, only what I know about it it's that we can regroupe a number of components in one group, but don't know more about the subject. But perhaps now I have a different vision of it)
                          so I broke my B component and leaved only A as a component, like this the CPU recognized probabily A and B as 2 differents objects, that's why CPU didn't changed A after rescaling B this time.
                          is it correct ?
                          p.s. it's really difficult to measure the radius of 2 different sizes of circle precilely with the TMT. In my opinion the entity info (elementinformationen) is better for rescale anykind of circles based forms, by starting from an empty circle and adjusting after
                          • ely862meE Offline
                            ely862me
                            You can rescale it directly .
                            [web 100%,396:1sqzi9pr]http://www.screenr.com/embed/JtRH[/web:1sqzi9pr]
                            Elisei (sketchupper)
                            Come and See EliseiDesign
                              Perhaps it would be easier to simply redraw one of the pipes so the diameters match? It's easy to get sucked into trying to repair something when the easier route would be to start over and do it right.
                              • E Offline
                                erzane
                                DaveR
                                yes sometime that's the best solution as you say
                                Eli862,
                                pls whitch tool did you use on 0:32 sec ?
                                  That's just the Move tool at :32.
                                  • E Offline
                                    erzane
                                    ok
                                    I didn't know it can do that
